ASA Conectivity Problem from Outside to DMZ several IP addresess, same MAC
I have one Server with one NIC, but configured with Three IP addresses. This Server is with NAT (0) in the ASA. The problemis that from Outside (Internet) I just can ping the first IP address y the others ones I can not ping. I see with "show arp" Three IP addresses and the same ARP, How can I resolve this problem I want to see my Three IP Addresses. I can see them from the LOCAL DMZ interface but not from outside. Please Help me.
1 ACCEPTED SOLUTION
Re: ASA Conectivity Problem from Outside to DMZ several IP addre
make static nat for each IP
in this case you gonna allow two way connectivity
if you wanna usethe same IP address as it on the DMZ
for example the server ip addressess 192.168.1.1, 192.168.1.2, 192.168.1.3
static (DMZ,outside) 192.168.1.1 192.168.1.1 netmask 255.255.255.255
static (DMZ,outside) 192.168.1.2 192.168.1.2 netmask 255.255.255.255
static (DMZ,outside) 192.168.1.3 192.168.1.3 netmask 255.255.255.255
and make and ACL on your outside interface to allow the connection from outsideinterface to those IPs
also enable ICMP inspection and ICMP error inspection
on you default global_policy
for pinging
good luck
please Rate if helpful
for pinging
good luck
Thanks a lot my friend.
That resolved my problem, I appreciate you time and you help.
Damian Mendoza.
u r always welcome :)
132
