ASA Config problem
Dear,
On pix i am having below commands in 8.2 version, Now i want to configure this commands on ASA 5525-x with IOS version 9.1 how can i configure this on ASA.
static (Inside,DMZ) 10.10.49.13  access-list Inside_nat_1
static (Inside,DMZ) 172.20.7.99  access-list Inside_nat_2
access-list Inside_nat_1 extended permit ip host 172.20.6.52 host 10.50.2.20
access-list Inside_nat_1 extended permit ip host 172.20.6.52 host 10.150.23.20
access-list Inside_nat_1 extended permit ip host 172.20.6.52 host 11.50.11.250
access-list Inside_nat_1 extended permit ip host 172.20.6.52 host 192.168.54.15
access-list Inside_nat_1 extended permit ip host 172.20.6.52 host 172.31.11.218
access-list Inside_nat_2 extended permit ip host 172.20.6.52 host 10.1.21.36
access-list Inside_nat_2 extended permit ip host 172.20.6.52 host 10.10.201.3
access-list Inside_nat_2 extended permit ip host 172.20.6.52 host 202.18.123.68
access-list Inside_nat_2 extended permit ip host 172.20.6.52 host 172.232.11.19
access-list Inside_nat_2 extended permit ip host 172.20.6.52 host 10.1.210.188
Please help on this.
Jitesh MAHAJAN.
  • Firewalling
VIP Green
Those commands would be
Those commands would be translated to the following commands in 8.3 and higher.
object network HOST
  host 172.20.6.52
object network NAT1
  host 10.10.49.13
object network NAT2
  host 172.20.7.99
object-group network DEST1
  host 10.50.2.20
  host 10.150.23.20
  host 11.50.11.250
  host 192.168.54.15
  host 172.31.11.218
object-group network DEST2
  host 10.1.21.36
  host 10.10.201.3
  host 202.18.123.68
  host 172.232.11.19
  host 10.1.210.188
nat (inside,DMZ) source static HOST NAT1 destination static DEST1 DEST1
nat (inside,DMZ source static HOST NAT2 destination static DEST2 DEST2
Please remember to select a correct answer and rate helpful posts
-- Please remember to rate and select a correct answer
Dear Marius,Thanks for your
Dear Marius,
Thanks for your reply.
mean while i am searching on Cisco Document i have receive the below format can this is work in 9.1 IOS.
object network Inside_nat_1
 subnet 172.20.6.52 255.255.255.255
 nat (Inside,DMZ) dynamic 10.10.49.13
 exit
object network Inside_nat_2
 nat (Inside,DMZ) dynamic 172.20.7.99
 exit
Jitesh Mahajan.
VIP Green
No this will not work the way
No this will not work the way you want it to work.  The following:
Will only translate 172.20.6.52 to 10.10.49.13...not to mention the syntax is incorrect as well...you should be using static instead of dynamic in the NAT...also the object, though it will work the way you have it, it is better to use the host keyword instead of subnet.
You need to use the format I provided in the earlier post.
Dear Marius,
Thanks for support,
I understand this.
i am also having same command:
old:
static (DMZ,Inside) 10.10.50.94 10.10.10.94 netmask 255.255.255.255
New:
object network obj-10.10.10.94
  host 10.10.50.94
  nat (DMZ,Inside) static 10.10.10.94
Can this will work?
Jitesh Mahajan.
VIP Green
You have the IPs switched
You have the IPs switched around.  It should look like this:
  host 10.10.10.94
  nat (DMZ,Inside) static 10.10.50.94
VIP Green
Thanks you for the rating
Thanks you for the rating smiley
Dear Marius,below is the
Dear Marius,
below is the commands of  pix 8.2 ver. I was converted this commands in 9.1 Version Can this correct.
Version  8.2
global (Outside) 10 220.226.206.81 netmask 255.255.255.255
global (Outside) 11 220.226.206.231 netmask 255.255.255.255
global (DMZ) 51 172.100.1.1 netmask 255.255.255.255
nat (Inside) 51 access-list Inside_nat_outbound
nat (Inside) 10 access-list Inside_Ti_outbound
nat (DMZ) 11 10.10.52.114 255.255.255.255
access-list Inside_Ti_outbound extended permit icmp host 172.20.1.100 host 220.226.206.1
access-list Inside_Ti_outbound extended permit ip host 10.10.49.40 any
access-list Inside_Ti_outbound extended permit ip host 10.10.49.52 any
access-list Inside_nat_outbound extended permit tcp host 10.24.126.117 host 192.168.100.10 eq 9097
access-list Inside_nat_outbound extended permit tcp host 10.24.126.113 host 192.168.100.10 eq 9097
access-list Inside_nat_outbound extended permit tcp host 10.24.65.19 host 192.168.100.10 eq 9097 inactive
Version 9.1
object network DMZ-NAT
 subnet 10.10.52.114 255.255.255.255
 nat (Cust-DMZ,ECS-Outside) dynamic 220.226.206.231
object network INSIDE-51-1
 subnet 10.24.126.117 255.255.255.255
 nat (Inside,DMZ) dynamic 172.100.1.1
object network INSIDE-51-2
 subnet 10.24.126.113 255.255.255.255
object network INSIDE-51-3
 subnet 10.24.65.19 255.255.255.255
object network INSIDE-10-1
 subnet 172.20.1.100 255.255.255.255
 nat (Inside,Outside) dynamic 220.226.206.81
object network INSIDE-10-2
 subnet 10.10.49.40 255.255.255.255
object network INSIDE-10-3
 subnet 10.10.49.52 255.255.255.255
Jitesh Mahajan.
VIP Green
The commands would be the
The commands would be the following.  please remember to make a backup of your current configuration so you are able to rollback in case this does not work.
object network obj_172_20_1_100
  host 172.20.1.100
object network obj_220_226_206_81
  host 10 220.226.206.81
object network obj_192_168_100_10
  host 192.168.100.10
object-group network Inside_Ti_outbound
  network-object host 10.10.49.40
  network-object host 10.10.49.52
object-group network Inside_nat_outbound
  network-object host 10.24.126.113
  network-object host 10.24.126.117
  network-object host 10.24.65.19
network object obj_220_226_206_1
  host 220.226.206.1
object network obj_172_100_1_1
  host 172.100.1.1
object-group network obj_10_10_52_114
  network-object host 10.10.52.114
  nat (DMZ,Outside) dynamic 220.226.206.231
object service 9097
  service tcp destination 9097
nat (inside,Outside) source static obj_172_20_1_100 obj_10_220_226_206_81 destination static obj_220_226_206_1 obj_220_226_206_1
nat (inside,Outside) source static Inside_Ti_outbound obj_220_226_206_81
nat (inside,DMZ) source static Inside_nat_outbound obj_172_100_1_1 destination static obj_192_168_100_10 obj_192_168_100_10 service 9097 9097
95
