ASA connection timeout
Hi All,
there are two connection timeout on ASA:
#timeout connection ...
and the other one through class-map/policy-map with:
#set connection timeout ....
if we have both, I guess class-map/policy-map has higher priority.
any suggestion would be very appreciated as always.
Alex
Re: ASA connection timeout
Alex,
What is the question? Are you asking which one is preferred?
If you want to allow specific timeout setting for a certain flow, that is only possible via MPF.
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/s1.html#wp1424605
-KS
thanks for the reply.
we have both configuration in ASA. does  "set connection timeout" in MPF override the "timeout" command?
Yes.
-KS
3409
