Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA Control Plane
I'm attempting to limit what IP addreses can connect to an ASA using the SSL VPN. I would have thought control-plane policing would have worked, however it did not.
Here is what I configured:
access-list vpn_control extended permit tcp object-group allowed_clients interface outside
access-group vpn_control in interface outside control-plane
any suggestions would be appreciated.
Thanks!
Silver
ASA Control Plane
Please post more of the configuration and check logs to see what you are reporting, by any chance do you have http server enable, can you get me a show run http.
Check the following link that contains and explanation:
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/a1.html#wp1541842
Note Access control rules for to-the-box management traffic (defined by such commands as http, ssh, or telnet) have higher precedence than an access list applied with the control-plane option. Therefore, such permitted management traffic will be allowed to come in even if explicitly denied by the to-the-box access list.
Value our effort and rate the assistance!
VIP Green
Re: ASA Control Plane
The command you entered for the control plane is for traffic destined  for the ASA itself...but also VPN traffic will bypass the interface  ACLs as it is encrypted by default.
You could try to issue the command no sysopt connection permit-vpn this will require the ASA to check the SSL VPN traffic against the interface configured ACL
Please rate any helpful posts.
Please remember to rate and select a correct answer
Silver
ASA Control Plane
This would be for traffic through the ASA and not really to the ASA.
The sysopt connection permit-ipsec command allows all the traffic that enters the security appliance through a VPN tunnel to bypass interface access lists. Group policy and per-user authorization access lists still apply to the traffic. In PIX/ASA 7.1 and later, the sysopt connection permit-ipsec command is changed to sysopt connection permit-vpn. The vpn-filter is applied to post-decrypted traffic after it exits a tunnel and pre-encrypted traffic before it enters a tunnel.
VIP Green
ASA Control Plane
Yes I know, but it is a option none the less
ASA Control Plane
Agree, The option to go is the control-plane one.
As far as I am aware that should do it.
Example:
access-list outside-control-plane extended deny tcp host 1..1.1.1 x.x.x.x eq 443 (where x.x.x.x is the Out interface IP)
access-group outside-control-plane in interface outside control-plane
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Jcarvaja
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Silver
ASA Control Plane
VIP Green
ASA Control Plane
@ jumora - you are correct, however this is only applicable for managment traffic.  To me it sounds like Spagsterj wants to limit IPs that are able to initiate an SSL VPN session.  As PKI will exchange keys before any traffic is sent between the devices, the traffic will be encrypted when the actual connection is made and will therefore bypass the outside interface ACL by default.  So (unless my logic is completely off here) he will need to disable the ACL bypass for it to take effect.
Silver
ASA Control Plane
That is the issue, the ASA does not distinguish this if it is SSL VPN or management, I work at TAC and escalated a ticket a couple of days due to this, it is also related to class type management that did not work for SSL traffic but did for SSH.
Believe me I know what I'm talking about.
ASA Control Plane
Hello Marius,
Agree with Juancito "loquillo" in this one as what the customer is trying to accomplish is filter who connects to the Firewall via SSL, not what traffic is allowed to go via the tunnel.
In this case the control-plane option is the suitable option.
Cheers to boh of you.
Jcarvaja
Julio Carvajal
VIP Green
ASA Control Plane
Hi Julio,
That is my understanding too.  I don't think I mentioned traffic filtering...or did I?   I will have a read through the posts and see.
Anyway, I am wondering if perhaps the ACL assigned to the control plane is being bypassed due to the encryption, which is why I suggested trying to disable the interface ACL bypass by using the following command:
Silver
ASA Control Plane
Ok, do you still need assistance?
Julio knows me and please believe me when I correct anyone it´s not to presume it´s because I want them to understand.
Customer to you still need assistance???
ASA Control Plane
Has there been any change regarding filtering what source IP address can initiate an SSL connection to the ASA for VPN access?
Bbb
VIP Green
ASA Control Plane
Do you still require assistance with this issue?  If not please rate the helpful posts.
Silver
ASA Control Plane
If you rate we assist if not black list
ASA Control Plane
I'm having a problem which I think is described here.  I would essentially like to whitelist networks for ssl anyconnect vpn access.  I understand that the anyconnect client would attempt a connection to my outside interface on 443 and that it would be considered "to the box traffic" which would bypass the interface ACL's. I set up an acl to deny traffic from a specific test network to test the control plane option.  At first I tried 443 traffic and later expanded it to a deny any from the external network, but in either case I was still able to VPN to the asa from this test network using the anyconnect client.  I assume this has something to do with management traffic having priority and not distiguishing between managment traffic destined for /admin and ssl vpn connections.  However, I do not have the outside interface enabled as a management interface, so even that is a little puzzling.
access-list outside_access_in_1 extended deny ip object test_network any
access-list outside_access_in_1 extended permit ip any any
access-group outside_access_in_1 in interface outside control-plane
If I do a packet trace for 443 traffic from that network to my outside interface IP it does show the traffic passing and the ACL section specifically shows it passing via implicit rule...
Let me work on this and Get back to you,
Looking for some Networking Assistance?
Contact me directly at jcarvaja@laguiadelnetworking.com
I will fix your problem ASAP.
Cheers,
Julio Carvajal Segura
Julio Carvajal
I had the same problem too
I had the same problem too and figured out a solution. The problem being the control plane ACL is not blocking traffic from hosts residing on the non whitelist networks. In other words there is no permit statement covering connection from the unwanted host but unwanted host are still able to bypass the ACL and make connection directly to the box/ASA.
access-list ssl2box extended permit object tcp-883 202.144.2.0 255.255.255.0 any
access-group ssl2box in interface outside control-plane
To clarify a few things in my particular setup:
  • For webvpn ssl the ASA5505 is listening on non standard port (for example tcp/883)
  • For http server management (only allowed for access from hosts residing behind the internal interface) the firewall is listening on tcp/444
  • For my internal hosted site (sits behind ASA5505) I'm performing port forward (tcp/443) from outside interface IP to internal IP.
What worked for me is adding in the explicit deny:
access-list ssl2box extended deny object tcp-883 any interface outside log
Viewing the access list hits shows what happens when a connection attempt is made from an IP not permitted (i.e. not on the whitelist):
access-list ssl2box line 7 extended deny tcp any interface outside eq 883 log informational interval 300 (hitcnt=1) 0xb35c358c
Strangely, implicit deny for the control-plane ACL did bugger all !
Interested to hear if this post has helped anyone..
4174
