Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ASA CPU higher than normal
Our ASA CPU level has been higher than normal over the last few weeks and I can see a reason why.
I have noiced that tha dashboard has had the top graphs/tables re-enabled, which I beleive can cause the CPU to rise, how can I turn these off again?
Can you share
Show processes cpu-usage sorted non-zero
Clear interfaces
show interface | include errors
After 5 minutes
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Re: ASA CPU higher than normal
Sure:
show processes cpu-usage non-zero
PC                    Thread         5Sec      1Min     5Min     Process
0x09303f3c   0x6d5ac568      0.1%      0.0%     0.0%     websns_snd
0x0911595d   0x6d5ac778     0.1%      0.1%     0.1%     websns_rcv_tcp
0x08c7e425   0x6d5c0b48     0.1%      0.1%     0.0%     Unicorn Admin Handler
0x0911d204   0x6d5af0b8      0.5%      0.4%     0.4%     tcp_thread
0x090c7a4d   0x6d5a6688     0.1%      0.0%     0.0%     ssh
0x091618b9   0x6d5ab6f8      0.0%      0.1%     0.1%     snmp
0x087a174e   0x6d5af8f8       0.1%      0.1%     0.1%     IP Thread
0x0865991b   0x6d5b3d08     0.0%      0.1%     0.1%     IKE Daemon
0x0828fb01   0x6d5c3278      68.8%    62.3%    59.7%   Dispatch Unit
0x098a2535   0x6d5bb8c8     0.0%      0.1%     0.0%     Checkheaps
0x087a8efe   0x6d5af6e8       0.1%      0.0%     0.0%     ARP Thread
        0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
        790 input errors, 0 CRC, 0 frame, 790 overrun, 0 ignored, 0 abort
        637 input errors, 0 CRC, 0 frame, 637 overrun, 0 ignored, 0 abort
So the CPU is high due to DIspatch Unit process (Traffic handeling related)
That being said we can see that interface 1 and 2 are the ones receiving more traffic.
So my recommendation is:
Clear the interfaces with the command
clear interfaces
give 4 minutes
and do
show interfaces | include errors
Also run
show local-host | includehost|count/limit
And look for the hosts with the largest amount of conn.
Jcarvaja
Julio Carvajal
Will do, just noticed this didn't work:
ERROR: % Invalid input detected at '^' marker.
It's
show local-host | include host|count/limit
Jcarvaja
Julio Carvajal
Silver
Strong suggestion would be to use Netflow and collector of choice against a Cisco switch that can monitor real time, the reason I state this is because if you need to cut down someone that is doing something that you are not allowing you would need to wait for the flow to close down to identify the source through Netflow on the ASA but on a Cisco switch you would identify the source immediately.
You can also enable threat detection feature that will tell you who is the top talker at a moment but not a history of that user.
https://supportforums.cisco.com/docs/DOC-6113
Value our effort and rate the assistance!
513
