Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA - cut through proxy authentication for RDP?
I know how to set this up on a router (dynamic access-list - lock and key)... But, I'm having trouble understanding how to setup OUTSIDE to INSIDE cut through proxy authentication for RDP.
OUTSIDE to INSIDE RDP is currently working.
I have 2 servers I want RDP open for..
[*]OUTSIDE 1.1.1.1 to INSIDE 10.10.70.100
[*]OUTSIDE 1.1.1.2 to INSIDE 10.10.50.200
What's required for OUTSIDE users  to authenticate on the ASA before allowing port 3389 opens? I was hoping for is a way to SSH into this ASA, login with a special user, then have the ASA add a dynamic ACE on the OUTSISE interface to open 3389 for a designated time limit. Is this possible?
Here is my current config.
[code]
ASA Version 8.2(5)
hostname ASA5505
names
name 10.10.0.0 LANTraffic
name 10.10.30.0 SALES
name 10.10.40.0 FoodServices
name 10.10.99.0 Management
name 10.10.20.0 Office
name 10.10.80.0 Printshop
name 10.10.60.0 Regional
name 10.10.70.0 Servers
name 10.10.50.0 ShoreTel
name 10.10.100.0 Surveillance
name 10.10.90.0 Wireless
interface Ethernet0/0
description TO INTERNET
switchport access vlan 11
interface Ethernet0/1
description TO INSIDE 3560X
switchport access vlan 10
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
interface Vlan1
no nameif
security-level 50
no ip address
interface Vlan10
description Cisco 3560x
nameif INSIDE
security-level 100
ip address 10.10.1.1 255.255.255.252
interface Vlan11
description Internet Interface
nameif OUTSIDE
security-level 0
ip address 1.1.1.1 255.255.255.224
ftp mode passive
clock timezone PST -8
clock summer-time PDT recurring
dns domain-lookup OUTSIDE
dns server-group DefaultDNS
name-server 8.8.8.8
name-server 4.2.2.2
domain-name test.local
access-list RDP-INBOUND extended permit tcp any host 1.1.1.1 eq 3389
access-list RDP-INBOUND extended permit tcp any host 1.1.1.2 eq 3389
pager lines 24
logging enable
logging timestamp
logging trap warnings
logging device-id hostname
logging host INSIDE 10.10.70.100
mtu INSIDE 1500
mtu OUTSIDE 1500
ip verify reverse-path interface OUTSIDE
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-645.bin
no asdm history enable
arp timeout 14400
global (OUTSIDE) 1 interface
nat (INSIDE) 1 LANTraffic 255.255.0.0
static (INSIDE,OUTSIDE) tcp interface 3389 10.10.70.100 3389 netmask 255.255.255.255
static (INSIDE,OUTSIDE) tcp 1.1.1.2 3389 10.10.50.200 3389 netmask 255.255.255.255
access-group RDP-INBOUND in interface OUTSIDE
route OUTSIDE 0.0.0.0 0.0.0.0 1.1.1.1 1
route INSIDE LANTraffic 255.255.0.0 10.10.1.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
http server enable
http Management 255.255.255.0 INSIDE
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 10.10.70.100 255.255.255.255 INSIDE
ssh Management 255.255.255.0 INSIDE
ssh 0.0.0.0 0.0.0.0 OUTSIDE
ssh timeout 5
ssh version 2
console timeout 0
threat-detection basic-threat
threat-detection scanning-threat shun
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
username scott password CNjeKgq88PLZXETE encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:1e9d278ce656f22829809f4c46b04a07
: end
[/code]
Hall of Fame Super Silver
You're running ASA 8.2(5). In 8.4(2) Cisco added support for what they call Identity Firewall rules. That is, you can make access-lists entries specific to users (or object groups containing users).
There's an overview document on this posted here. It's a bit dated but I believe the only change is that Cisco is now preferring use of the more current Context Directory Agent (CDA) - a free VM they provide - vs. the deprecated AD agent (software service that runs on your DC).
Community Member
Re: ASA - cut through proxy authentication for RDP?
Thank you..
It seem's as though my current ASA 8.2(5) version does not offer the type of authentication features I'm wishing to implement?
I'm begining to think the only way to deploy a secure RDP on this 8.2(5) is through the ASA Clientless SSL VPN: RDP Plug-in.. Does that seem accurate?
Thanks for your answer..
Hello, Scott.
Microsoft RDP protocol could be protected by SSL encapsulation, that Microsoft called as "RD Gateway".
This solution allows you to control access per user/per destination at the same time using SSL for authentication and data protection.
The solution is really scalable.
Clientless SSL VPN with the RDP plug-in is viable. It would require Anyconnect Premium licenses though.
You could also do SSL (or IPsec) remote access VPN with access-list tied to the users (or group profile that a set of users are authorized use).
840
