ASA CX failover
We have a Pair of ASA 5515-X in active/passive failover, each with CX module.
While the ASAs remain aligned to any changes in the configuration, it is not so for the CX module - that seems to be totally independent from each other and need to be configurate separately.
We spent a lot of time trying to solve this problem, but without finding the solution:
Is there a way to maintain the same configuration between the CXs, without using the Prism Security Manager?
It is obvious that I can not propose to a customer who purchases a pair of ASAs, also to set up a virtual appliance and buy a license.
Best regards,
Claudio
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
PRSM in multi-device mode (
PRSM in multi-device mode ("off-box") is the only way to maintain automatic synchronization between a pair of CX modules installed in an HA pair of ASAs.
Without that you have to make the same changes manually in each ASA's CX module via PRSM on-box (single device mode).
Thanks for the answer.I find
I find this choice of Cisco really mad.
I understand that Cisco wants to "force" a customer to buy PRSM off-box, but the only result is that I can no longer propose a failover pair of ASA-CX to a Customer, because the total quote is out of market.
And then I will use products of other brands.
Best regards
I wouldn't be surprised to
I wouldn't be surprised to see this particular behavior change in future releases. Your complaint is shared by many customers and partners - both large and small.
Overall, the CX and PRSM feels a bit "rushed to market". Have a look at the release notes and the astonishing amount of bugs being addressed in the very small incremental point releases.
153
