ASA DMZ - Un-NATed DMZ with PUBLIC IPs - Did I do it right?
Hey folks,
Consider the following - is this a "correct" way of making a DMZ where you can assign public IPs to the hosts?
It is expected that hosts placed in this segment has a firewall of its own. Its from ASA software v8.6.
interface GigabitEthernet0/1.100
 vlan 100
 nameif X-net-WAN
 security-level 50
 ip address 5.5.5.1 255.255.255.240
object network X-net-WAN
 subnet 5.5.5.0 255.255.255.240
nat (X-net-WAN,outside) source static X-net-WAN X-net-WAN
access-group outside-in in interface outside
access-list outside-in extended permit ip any 5.5.5.0 255.255.255.240
Everything seems to be working fine. A packet-tracer gives the following:
Phase: 1
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
Additional Information:
NAT divert to egress interface X-net-WAN
Untranslate 5.5.5.2/80 to 5.5.5.2/80
... snip
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: X-net-WAN
output-status: up
output-line-status: up
Action: allow
Is the type UN-NAT the same as the old pre v8.3 nat-exempt?
Do you agree on this method or do you have a better way of doing it?
Thx in advance!
1 ACCEPTED SOLUTION
Silver
This is a perfectly correct
This is a perfectly correct configuration.
With Packet Tracer (PT) we can inject real packet into the ASA forwarding plane and see what’s going on. For NAT we can have three sections in the PT output (called Phases):
  • NAT – shows how the source of the packet will be translated
  • UN-NAT – shows how the destination of the packet will be translated
  • NAT RPF-CHECK – shows how might/should source of the returning packet be translated (RPF – Reverse Path Forwarding)
Refer: https://supportforums.cisco.com/discussion/11877356/un-nat-question
"Please rate helpful posts"
1 REPLY
Silver
40
