Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Silver
ASA failover and HSRP gw
Hello All,
I have two ASA5520 (with 7.2 software) in statful failover over LAN. And these firewalls are connected to my border routers, on border routers HSRP operates and provides virtual address - HSRPprovide the next hop for outside static route. My problem is that I receive the next syslog message:
%ASA-4-405001: Received ARP response collision from "ASA outside IP"/0000.0c07.ac00 on interface outside
And after this message the Active ASA fail and secondary become active.
Please send me some info how to solve this issue.
Thanks in advance
FCS
Bronze
Re: ASA failover and HSRP gw
If you have uploaded the complete error message, it seems that there is an IP conflict. The device with the mac address 0000.0c07.ac00 must be having an IP which is already present on the firewall.
You will have to check the mac address 0000.0c07.ac00 . By checking i mean, you will have to trace this mac address. You can check your L2 switch for its mac address table. See from which port it is learning this mac address. If it is a cisco switch check by
show mac-address-table
Pls let me know if 0000.0c07.ac00 belongs to the ASA itself.Then it has to be some other issue.
regards
Zubair
--Pls rate if it helps--
Silver
Zubair,
0000.0c07.ac00 is HSRP virtual mac address as I know.
bye
FCS
Bronze
Check the following bug id's CSCsc34022 and CSCsc47618. Maybe it is of some help.
regards
Zubair
Silver
Thanks again Zubar...
But this bugs are different what I expect. My standby asa can take over the resources, when this arp issue is appear. And the mac address is coming from my border routers (they are HSRP pair).
FCS
532
