Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA Failover between three ASA
I want to make this senario for failover like in attached picture,
for ASA-A its connected to deffrent ISP of ASA-B, and every ASA handle deffrent network, can i put another ASA with two context as standby for actives FW's
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
No - sorry that will not work
No - sorry that will not work.
"The two units in a failover configuration must:
Be in the same context mode (single or multiple)."
Source.
Source.
VIP Purple
As Marvin stated, it won't
As Marvin stated, it won't work as in your picture.
But if you don't need any features that are not available in multiple-context-mode, then you could configure Active/Active-failover between ASA-A and ASA-B with one context for the operation of ASA-A and another Context for the operation of ASA-B.
Good suggestion, Karsten.The
The only caveat that brings to mind is that remote access VPN isn't supported in multi-context mode. So if that's in use they couldn't go that route.
p.s. hope to see you at Cisco Live this year.
101
