each time i have a majpr upgrade to the AIP-SSM , it has to be restarted and the ASA will do a failover, is there a solution for this ? a way not to let ASA monitor the AIP-SSM ?
You can disable the ASA not to moniter the AIPSSM.
config#policy-map abcpolicy
#class abc
#no ips inline fail-open (or fail close whatever u have on that line )
Raj
