ASA Failover | failover group ?
We just purchased two asa firewall to be setup in an active/active configuration. But when im doing my initial configuration, the failover group command is somewhat missing
ASA1(config)# failover ?
configure mode commands/options:
  interface         Configure the IP address to be used for failover and/or
                    stateful update information
  interface-policy  Set the policy for failover due to interface failures
  ipsec             Configure the use of IPSec tunnel for failover
  key               Configure the failover shared secret or key
  lan               Specify the unit as primary or secondary or configure the
                    interface and vlan to be used for failover communication
  link              Configure the interface and vlan to be used as a link for
  mac               Specify the virtual mac address for a physical interface
  polltime          Configure failover poll interval
  replication       Enable HTTP (port 80) connection replication
  timeout           Specify the failover reconnect timeout value for
                    asymmetrically routed sessions
  <cr>
exec mode commands/options:
  active          Make this system to be the active unit of the failover pair
  exec            Execute command on the designated unit
  reload-standby  Force standby unit to reboot
  reset           Force a unit or failover group to an unfailed state
Looking at the license, i got this
Licensed features for this platform:
Maximum Physical Interfaces       : Unlimited      perpetual
Maximum VLANs                     : 150            perpetual
Inside Hosts                      : Unlimited      perpetual
Failover                          : Active/Active  perpetual
Encryption-DES                    : Enabled        perpetual
Encryption-3DES-AES               : Enabled        perpetual
Security Contexts                 : 2              perpetual
GTP/GPRS                          : Disabled       perpetual
AnyConnect Premium Peers          : 2              perpetual
AnyConnect Essentials             : Disabled       perpetual
Other VPN Peers                   : 750            perpetual
Total VPN Peers                   : 750            perpetual
Shared License                    : Disabled       perpetual
AnyConnect for Mobile             : Disabled       perpetual
AnyConnect for Cisco VPN Phone    : Disabled       perpetual
Advanced Endpoint Assessment      : Disabled       perpetual
UC Phone Proxy Sessions           : 2              perpetual
Total UC Proxy Sessions           : 2              perpetual
Botnet Traffic Filter             : Disabled       perpetual
Intercompany Media Engine         : Disabled       perpetual
Cluster                           : Disabled       perpetual
ASA1(config)# failover group 1
ERROR: % Invalid input detected at '^' marker.
Active/Active failover is enable
Anybidy have an idea what am i missing?
Everyone's tags (3)
Have you already configured failover? Are you in the system context?
Thanks Collin.
Already figured it out. I was still in single mode
I'll continue the configuration and if I come across any issue, i'll post it here.
Wish me luck
614
