ASA Failover issue (Primary_group_1) Lost Failover communications with mate on interface dmz
HI ,
We are running with Cisco ASA 8.0.5 in multiple context mode please find configuration details for the same
Failover On
Failover unit Primary
Failover LAN Interface: asa-mgmt-failover Management0/0 (up)
Unit Poll frequency 3 seconds, holdtime 9 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 11 of 250 maximum
Version: Ours 8.0(5)23, Mate 8.0(5)23
Group 1 last failover at: 15:38:00 IST Jul 11 2013
  This host:    Primary
  Group 1       State:          Active
                Active time:    21634557 (sec)
                slot 0: ASA5550 hw/sw rev (2.0/8.0(5)23) status (Up Sys)
                  admin Interface outside (203.99.214.71): Normal
                  admin Interface dmz (10.224.1.153): Normal
                  admin Interface jpmc (10.224.1.137): Normal
                  admin Interface inside (10.224.1.36): Normal
                  admin Interface wan (10.224.1.1): Normal
                  abc Interface wan (10.224.1.201): Normal
                  abc Interface odc (10.224.1.145): Normal
                  xyz Interface outside (10.224.1.193): Normal
                  xyz Interface bms (10.224.63.1): Normal
                  lkj Interface outside (10.224.1.218): Normal
                  lkj Interface inside (10.224.35.5): Normal (Not-Monitored)
                  lkj Interface dmz (10.224.37.129): Normal
                slot 1: ASA-SSM-4GE-INC hw/sw rev (1.0/1.0(0)10) status (Up)
  Other host:   Secondary
  Group 1       State:          Standby Ready
                Active time:    33 (sec)
Stateful Failover Logical Update Statistics
        Link : asa-mgmt-failover Management0/0 (up)
        Stateful Obj    xmit       xerr       rcv        rerr
        General         27756222057 0          2898148    23383
        sys cmd         2884433    0          2884432    0
        up time         0          0          0          0
        RPC services    0          0          0          0
        TCP conn        21161285056 0          8729       16454
        UDP conn        6448374101 0          4943       6929
        ARP tbl         143539325  0          44         0
        Xlate_Timeout   0          0          0          0
        SIP Session     139142     0          0          0
        Logical Update Queue Information
                        Cur     Max     Total
        Recv Q:         0       12      2898148
        Xmit Q:         0       17      27756222078
And according to the syslog server, everything was good until 12:45pm, when this started:
Apr 08 12:45:38 10.22.151.58 local5.alert Apr 08 2009 12:49:55: %ASA-1-105005: (Primary) Lost Failover communications with mate on interface management-con1
Apr 08 12:45:38 10.22.151.58 local5.alert Apr 08 2009 12:49:55 %ASA-1-105005: (Primary_group_1) Lost Failover communications with mate on interface dmz
Apr 08 12:45:38 10.22.151.58 local5.alert Apr 08 2009 12:49:55: %ASA-1-105008: (Primary) Testing Interface management-con1
Apr 08 12:45:38 10.22.151.58 local5.alert Apr 08 2009 12:49:55: %ASA-1-105009: (Primary) Testing on interface management-con1 Passed
No outage, no failover, just an inability to remotely manage the device outside of the console.
I would highly appritiate if any one can give me solution for this failove message founf in syslog server.
Pranav
Hello Pranav,
Well looks like there are some communication issues between this guys at that time,
Is there a switch between this 2 devices?
Can you check the logs from the device?
at the moment we are up and running right?
It looks like we fail one of the tests that we run in order to determine whether failover is up or not.
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.
Any question contact me at jcarvaja@laguiadelnetworking.com
Cheers,
Julio Carvajal Segura
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Julio ,
Thanks for reply.. Currently we are not having any switch in between two ASA's.. Yes currently both ASA are in live and up and running.
Last failover happened on Jul 11 2013
Is that issue with any poll frequency ? thats why even if no failover happend we found failover message on syslog.
Pranav
501
