Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA failover issue
Dear concern,
We have two ASA 5520 and configured lan base fail over.
But failover not working as per expectation.
Please find attachment of show tech of both ASA.
Imran
Community Member
Re: ASA failover issue
u need to sub-interface the failover interface and connect with a cross cable, and finish of the configuration as per the attachment
AP
Community Member
Hi, from what I see the firewall failover is well configured, you have not configured the stateful failover feature, which allows for all connections, IPsec sessions, etc to be synced with he secondary unit. The command should do the job for you:
failover link sync GigabitEthernet0/1
Community Member
Hi marc-andre,
Can I have two ASA's connected via a single ethernet cable (ASA-1 G0/3 and ASA-2 G0/3)?
Can I use IP address for those interface that are not in my routing table (1.1.1.1 & 1.1.1.2)?
What are the most basic commands needed?
thanks
Community Member
Yes you can.
I have connected them directly with a straight cable and the configuration is as follows:
Firewall1# sh runn failover
failover
failover lan unit primary
failover lan interface stateful Management0/0
failover polltime unit msec 200 holdtime msec 800
failover polltime interface msec 500 holdtime 5
failover link stateful Management0/0
failover interface ip stateful 192.168.254.1 255.255.255.252 standby 192.168.254.2
Firewall2# sh runn failover
failover
failover lan unit secondary
This configuration is working for me.
266
