07-28-2013 05:36 AM - edited 03-11-2019 07:18 PM
Dears all,
I have some issue on ASA active and standby devices. the below behaviour is normal or abnormal, because we are facing slow network. Can you tell me about below errors.
Monitored Interfaces 11 of 1025 maximum
Version: Ours 8.4(4)1, Mate 8.4(4)1
Last Failover at: 18:56:49 UTC Oct 24 2012
This host: Secondary - Active
Active time: 23936387 (sec)
slot 0: ASA5585-SSP-20 hw/sw rev (1.0/8.4(4)1) status (Up Sys)
Interface voice (192.168.9.1): Normal (Monitored)
Interface ServersZone (192.168.10.1): Normal (Monitored)
Interface serv_dev (192.168.12.1): Normal (Monitored)
Interface serve_quality (192.168.13.1): Normal (Monitored)
Interface ERPZone (192.168.14.1): Normal (Not-Monitored)
Interface vmware (192.168.17.1): Normal (Monitored)
Interface Storage_Blade (192.168.18.1): Normal (Monitored)
Interface VM_KERNEL (192.168.19.1): Normal (Not-Monitored)
Interface access_control (192.168.30.1): Normal (Monitored)
Interface security_device (192.168.33.1): Normal (Not-Monitored)
Interface net_mgmt (192.168.34.1): Normal (Monitored)
Interface cam_mgmt (192.168.35.1): Normal (Not-Monitored)
Interface OUTSIDE (192.168.32.18): Normal (Monitored)
slot 1: empty
Other host: Primary - Standby Ready
Active time: 837 (sec)
Interface voice (192.168.9.2): Normal (Monitored)
Interface serv_dev (192.168.12.2): Normal (Monitored)
Interface serve_quality (192.168.13.2): Normal (Monitored)
Interface ERPZone (192.168.14.2): Normal (Not-Monitored)
Interface vmware (192.168.17.2): Normal (Monitored)
Interface Storage_Blade (192.168.18.2): Normal (Monitored)
Interface VM_KERNEL (192.168.19.2): Normal (Not-Monitored)
Interface access_control (192.168.30.2): Normal (Monitored)
Interface security_device (192.168.33.2): Normal (Not-Monitored)
Interface net_mgmt (192.168.34.2): Normal (Monitored)
Interface cam_mgmt (192.168.35.2): Normal (Not-Monitored) ------> this behaviour is normall or not?
slot 1: empty
show failover state
State Last Failure Reason Date/Time
This host - Secondary
Active Ifc Failure 18:56:45 UTC Oct 24 2012
Other host - Primary
Standby Ready Ifc Failure 18:56:49 UTC Oct 24 2012
access_control: Failed ----> This is normal behavoiur
net_mgmt: Failed
====Configuration State===
Sync Done - STANDBY
====Communication State===
Mac set
which i was highlighted in bold not monitored is normal or any issue.
07-28-2013 07:56 AM
The not-monitored / monitored state is just telling you how failover is configured. We typically setup ASA to monitor all active interfaces so that if any one goes down a failover event is triggered. (Reference)
Your "show failover state" output explains that the last failover event was due to loss of connectivity on two interfaces on the Primary unit.
Since the current state is "Secondary - Active" and "Primary - Standby Ready", all is well with respect to the ASA failover pair.
07-28-2013 08:02 AM
To add to Marvin's explanation, refer to the below link...
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/s3_72.html#wp1285409
Thx
MS
