06-18-2012 02:05 AM - edited 03-11-2019 04:20 PM
Hi all,
I configured the ASA failover for one of our customer. The actual problem is that if one interface of the active ASA fails it doesn't switch over to the standby unit. We have to shutdown the primary unit to bring the standby to the active state.
What could be the issue?
Is it due to ASA image bug and needs upgrade?
Your early response highly appreciated.
Thx
06-18-2012 04:40 AM
Hi Arumugasamy,
This depends on two things, whether the interface is monitored or not and your interface policy. You can check the output of:
show run monitor
and check if it is a monitored interface or not.
Also check, show failover output, this would tell you your interface policy, for more details refer to the command reference:
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/i3.html#wp1875181
Varun Rao
Security Team,
Cisco TAC
06-18-2012 06:19 AM
Thx a lot.
I will come back to you.
Swami.
Network Team Lead-Technical Support Services
Bahrain Business Machines,
General Marketing & Services Representative for IBM WTC
P.O. Box 10554, Manama, Bahrain
Mob: 00973 39063271
Dir: 00973 17584330
Fax: 00973 17584343
E-mail: swami@bh.gbm.ihost.com
Web: http://www.gbm4ibm.com
