Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA Failover VPN Issues
It seems each time our ASA's failover (at least once a month), that our Cisco VPN clients no longer connect with a error 433 unknown. Our Anyconnect clients work just fine. Failing back seems to do the trick. Is there anything specific I can look for once this happens again?
Re: ASA Failover VPN Issues
Hey Jason
Is the connectivity to the ASA's external IP fine, during this issue ? Is it a layer 3 issue or something to do at the top layers (authentication, encryption etc ) ?? Did you do a debug when users connect onto the failover ASA ? Hope there are software licenses on the failover unit ! do a debug crypto isakmp, debug aaa authentication etc, to see the exact error and troubleshoot from there ..
Hope this helps.. all the best..
Raj
HI Dear,
Which ASA software version you are using.
Is it 7.2(4)
This turned out to be a Cisco software bug. We were running 7.2(4) when we experienced the failover problem but upgraded to 7.2(4)9 and this resolved the issue.
The related bugs seem to have been:
CSCsl52895 - ASA 7.2.3 number of IPSec SA not replicated in failover unit.
CSCsl82200 - IPSec not encrypting after failover
There is also another bug to be aware of: search for CSCsi18736 in the bug toolkit.
Hope it will work for you.
Please feel free to revert if the isse still unresolved.
Kind Regards,
Sachin
Sachin,
I was using 8.0(3), but recently upgraded to 8.0(4), and everything seems to be working correctly on failover.
192
