ASA Failover
Can I know what is the difference between commands "Failover Lan" and "Failover Link". Which one enables stateful failover
Re: ASA Failover
"failover lan" is used to configure the basic failover configuration sync. "failover link" is for the stateful 'link' which exchanges state table info lile connections, etc.   - Magnus
Re: ASA Failover
The "failover LAN" command is used to specify the link used for failover
purposes while "failover link" command is used for specifying the link that
is used to exchange connection state information.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration
_example09186a00807dac5f.shtml#statef
Hope this helps.
NT
Re: ASA Failover
So which one should be used? Or if I want to enable statefull failover so that when my Primary firewall goes down, all the connection information should be passed to secondary set and secondary to act as active one. For this do  I need to enable both Lan failover as well as link faiolver?
Or is it if failover link only helps in sharing connection information to secondary firewall?
380
