N W
ASA failover
Guys
Quick question, to cover all basis.
Is there any thing I should look at when inplementing failover of two ASA.
The interface are VLAN's sub interfaces into a switch, with phsysical failover interface.
Just looking for something out of the ordinary.
1 ACCEPTED SOLUTION
Re: ASA failover
Looks good.
Just copy and paste the following on the other unit.
failover lan unit secondary
failover lan interface failover Ethernet0/0
failover key cisco123
failover link failover Ethernet0/0
failover interface ip failover 10.10.12.1 255.255.255.252 standby 10.10.12.2
and then enable failover  "failover". Make sure to issue "no shut" on the e0/0 interface on the secondary.
-KS
Re: ASA failover
Hi Noel,
Just a few checks regarding the hardware, software and license...
Hardware:
The two units in a failover configuration must have the same  hardware configuration. They must be the same model, have the same number and  types of interfaces, and the same amount of RAM.
Software:
The two units in a failover configuration must be in the operating modes (routed  or transparent, single or multiple context). They have the same major (first  number) and minor (second number) software version. However, you can use  different versions of the software during an upgrade process; for example, you  can upgrade one unit from Version 7.0(1) to Version 7.0(2) and have failover  remain active. CIsco recommends that you have the same major and minor version on both asas. ASDM image also must be the same.
License:
On the PIX 500 series security appliance, at least one of the  units must have an unrestricted (UR) license. The other unit can have a Failover  Only (FO) license, a Failover Only Active-Active (FO_AA) license, or another UR  license. Units with a Restricted license cannot be used for failover, and two  units with FO or FO_AA licenses cannot be used together as a failover pair.
Other than these, configuration wise, there's nothing else.
You can alse refer the link below for more information on failover:
http://www.cisco.com/en/US/customer/docs/security/asa/asa72/configuration/guide/failover.html#
Hope this answers your query.
Manisha Mandekar
N W
Re: ASA failover
Everything is the same, same box same RAM, same OS.
Is there anything on the CLI I shoudl look out for when inplement failover with sub interfaces? or will it work excatley the same was as with phsysical interfaces
Re: ASA failover
It works exactly the same as physical interfaces.
But 2 things to note here:
>> If you try to use a sub interface as a failover interface, its gonna give you an error:
"Can not configure failover interface on a shared physical interface"
This is because you can only use an unused Ethernet interface on the device as the failover link; and you cannot specify an interface that is currently configured with a name. The LAN failover link interface is not configured as a normal networking interface. It exists for failover communication only. This interface should only be used for the LAN failover link (and optionally for the stateful failover link)
>>Also, note that monitoring of physical interfaces is enabled by default; monitoring of logical interfaces is disabled by default.So if you want to monitor your sub interface, you will have to explicitly configure it using the command: monitor-interface
http://www.cisco.com/en/US/docs/security/asa/asa71/command/reference/m_711.html#wp1636148
Re: ASA failover
What i mean is:
If gi0/1 is the physical interface
ciscoasa1(config)# int g0/1
ciscoasa1(config-if)# exit
ciscoasa1(config)# int  g0/1.1
ciscoasa1(config-subif)# vlan 10
ciscoasa1(config-subif)#  exit
ciscoasa1(config)# failover link failover GigabitEthernet0/1.1
INFO: Non-failover interface config is cleared on GigabitEthernet0/1 and its  sub-interfaces
This works fine..... the physical interface is not being used for anything else.
But, if u configure a name for the physical interface:
ciscoasa1(config-if)# nameif  test
INFO: Security level for "test" set to 0 by  default.
ERROR: Can not configure failover interface on  a shared physical interface
Message was edited by: Manisha Mandekar
Re: ASA failover
You mentioned you are using a physical interface for failover.
Failover should work fine if you use sub-interfaces  for data.
The recommendation is that if you use the failover interface for state as well then, make sure it is as fast as the fastest data interface.
This means that when you use gig interfaces for inside and outside try NOT TO use a fast ethernet port for failover and state.
Refer our failover guide link here: http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/ha_overview.html#wp1077627
sampel failover config act/standby here:http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/ref_examples.html#wp1028629
-KS
N W
Re: ASA failover
Hi All
What I will have is one interface for failover (failover interface)
Than sub interfaces for passing data with a standby address on the sub interfaces. This is not part of the same failover interface.
Re: ASA failover
That is what I thought. Thanks for confirming.
Happy failover configuring
-KS
N W
Re: ASA failover
my config will look like this
interface Ethernet0/1
description trunk port
no shutdown
interface Ethernet0/1.1
description LAN
vlan 1
nameif inside
security-level 100
ip address 10.10.10.1 255.255.255.0 standby 10.10.10.2 no shutdown
interface Ethernet0/1.2
description DMZ
vlan 2
nameif DMZ
security-level 50
ip address 10.10.11.1 255.255.255.0 standby 10.10.11.2
no shutdown
interface Ethernet0/2
no shutdown
failover
failover lan unit primary
is this correct?
Re: ASA failover
Looks good.
-KS
N W
Re: ASA failover
thats what I had before and it failed.....
I'm trying it again within the hour and I'll post my findings, coz it is very very strange
N W
Re: ASA failover
thanks guys for your help
as I suspected it was noty a firewall issue. It was with the swiytching side.
thanks again
2138
