Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA Failover
Hi experts
My network setup has 2 number for ASA 5520 firewall configured in as Active-Standby setup.(ASA Version 8.2(1) )..One of the firewall is configured as Active and other is Standby..Recently we experienced automatic failover without any boot/failure of primary firewall or without any physical communication issue.The primary firewall was working fine still the failover has happened and standby firewall has become active..
From the documentation i could found following reasons for the failover...
  • The unit has a hardware failure or a power failure.
  • The unit has a software failure.
  • Too many monitored interfaces fail.
  • The no failover active command is entered on the active unit, or the failover active command is entered on standby unit.
Is there any other reason for the failover apart from 4 mentioned above....Setup is working fine and jsut want to understand the cause for the failover..
Re: ASA Failover
You can check the reason why the failover occured by issueing the command: show failover history
Here is the command reference for more information:
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/s3.html#wp1474400
Hope that helps to determine the possible issue.
Re: ASA Failover
Hello
Thanks for the quick reply..
Please find below the output of show history
------------------ show failover history ------------------
From State                 To State                   Reason
09:49:40 IST Oct 8 2010
Standby Ready              Just Active                Other unit wants me Active
Just Active                Active Drain               Other unit wants me Active
Active Drain               Active Applying Config     Other unit wants me Active
Active Applying Config     Active Config Applied      Other unit wants me Active
Active Config Applied      Active                     Other unit wants me Active
04:06:18 IST Oct 9 2010
Active                     Failed                     Interface check
04:06:35 IST Oct 9 2010
Failed                     Standby Ready              Interface check
07:47:30 IST Oct 9 2010
Standby Ready              Failed                     Interface check
07:47:33 IST Oct 9 2010
07:47:43 IST Oct 9 2010
07:48:00 IST Oct 9 2010
15:57:58 IST Oct 10 2010
15:58:15 IST Oct 10 2010
16:01:13 IST Oct 10 2010
16:01:15 IST Oct 10 2010
06:28:09 IST Oct 11 2010
it looks the connectivity issue happening since last 3 days but the final faiolver reason for today morning is not clear..
can you please help me in understanding the excat reason..
Re: ASA Failover
Looks like it failed because of interface failure. Can you also post the output of "show failover" from both units.
Also check each interfaces on the ASA firewalls, both physical cable as well as connection to the switch port. One of the interfaces could have failed, hence causing the issue.
ASA Failover
Hi there,
All monitored interface must be in "Normal" state.
If only one or more monitored interaces are "Failed" for any reason and Secondary unit will be "Failed" or most of time except short intervals being "Standby Ready".
You can test this option by typing in cfg mode  "no monitor-interace NAME_OF_FAILED_INT" after that Secondary unit has to be "Standby Ready"
ASA Failover
Hi there,
5080
