bma
ASA failover
We will use two ASA5520 do a failover. If install CSC-SSM in the primary, no CSC-SSM install in the secondary, is it ok for failover setup or what should happen when primary down?
ben
lus
Re: ASA failover
Hello Ben, what have you done with the failover? Does the failover work if no CSC-SSM is installed in the secondary ASA?
Thanks for your answer.
Re: ASA failover
My understanding of the ASA failover is that you must have the same OS and hardware on both units to enable failover.
129
