Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
bma
ASA failover
We will buy two ASA 5520 do failover, one ASA has CSC-SSM, no CSC-SSM in the failover one. Is it ok to config ASA failover with one CSC-SSM?
ben
Re: ASA failover
The units need to be the same in every aspect.
bma
Re: ASA failover
If we don't need CSC failover, only firewall is failover, is it ok with one CSC in the primary one?
ben
Re: ASA failover
No your system will not function properly. The two ASAs must be the same in every aspect hardware and software. The ironic part, although I do not see a setting for this, should the CSC have an issue, the unit will fail over.
Mike
183
