ASA Firewall failover triggers
Hello.
Can we have a failover triggered in a firewall. (ASA5540 - Active/Standby) based upon one or other interface failure similar to "track" command in HSRP.
Super Bronze
I think by default every normal physical interface will be monitored by the ASA. So one physical interface going down should trigger a failover.
If you want so that some interfaces going down doesnt trigger this you should be able to use "no monitor-interface " to disable monitoring on that interface.
You should also be able to use the command "failover interface-policy " to determine under what circumstances the failover will be triggered.
- Jouni
Thanks Jouni,
Sorry I am new to the world of firewalls. So it might seem a stupid one.. but just wanted to confirm, that if I have a firewall connected to two different LAN switches. Also I have active/standby failover configured using one of the LAN interface only.
So, if connection to any of the switch going down, will result in failover trigger?
124
