ASA firewall issue
I have configured remote access VPN with local pool in ASA firewall however im accessing all the resources(my private network such as servers ) through asa firewall after getting connected the VPN but i cant the mailing server through webmail(ports like 80).Please check the configs.
1 ACCEPTED SOLUTION
Re: ASA firewall issue
Would you please take a look at the split tunneling list? Where is the OWA server located?
Cheers.
Mike
Mike
Cheers.
Mike
Mike
It seems the OWA has 192.168.100.1 correct?
That IP is internal to the ASA via a static route.
In order for you to be able to reach that server via port 80, the server must be included in the nat0 ACL.
Question.
Can you PING 192.168.100.1 from the VPN client?
I just want to make sure that packets from the VPN client reaches the server and that the problem is specifically with the port 80.
Federico.
Hi....thanks.
    Yes.I can ping 192.168.100.1 from the vpn client.
     But i can't access web mail from the vpn client.
The OWA sserver is located at my Corporate office and the server ip is 192.168.100.1.After getting connected the vpn client,im pinging the server ip i.e 192.168.100.1 but i cant access my webmail.
R u considering the problem is at 80 port?
My OWA server locataed at my corperate office.
Bronze
Do you have a route on the 10.10.20.2 router, pointing the VPN pool back to the ASA ??
a route like,
ip route 172.16.1.0 255.255.255.0 10.10.20 1 ??
Cheers,
Nash.
Hi.....Thanks,
     But VPN ip pool was 182.16.1.1-182.16.1.10.Whenever he connected the vpn client,it will assigned this network 182.16.1.0
     Can i put this command,
       ip route 182.16.1.0 255.255.255.0 10.10.20.1?..
     Please advice me.
   Thanks.
Bronze
Was that a typo 182 in place of 172 ??
I saw the pool as 172.16.1.0/24 in the configuration.
Yeah, you could add that route
    ip route 172.16.1.0 255.255.255.0 10.10.20.1
If it is 182
then
Let me know how it goes.
Cheers,
Nash.
Hi.....
  When i put this command,it is saying,
    IFASA#
    IFASA#config terminal
    IFASA(config)#
    IFASA(config)# ip route 172.16.1.0 255.255.255.0 10.10.20.1
ERROR: % invalid input deteced at '^' maker
IFASA(config)#
Please advice me.
Thanks.
Bronze
Are you adding that route on 10.10.20.2 router ??
Cheers,
Nash
Hi......
    Ya.....i put this command the router.
   the command was ,
Thanks.
Bronze
What kind of a device is the 10.10.20.2 ??
is that an ASA or a Router ??
Cheers,
Nash.
Hi.......
   10.10.20.2 this kind of divice is that an ASA.
Thanks.
Bronze
On what interface is the 10.10.20.2 Ip address configured ??
Depending on the interface name,please add the following,
route "interface name" 172.16.10.0 255.255.255.0 10.10.20.1
For ex, if the 10.10.20.2 ip address is configured on the outside interface,
add
route outside 172.16.10.0 255.255.255.0 10.10.20.1
Cheers,
Nash.
Hi.....
   Ya i put this command,
route inside 172.16.1.0 255.255.255.0 10.10.20.1
but still not happened.
Thanks.
PING is a tool that can also work in suboptimal routing cases. First configure syslogging either in ASDM or to an external syslog server. Then try telnetting 192.168.100.1 on port 80 from the VPN client. Check if a blank screen appears, then filter the syslogs that contain 192.168.100.1 and paste here. Also a network diagram will be helpfull.
Hi....
    whenever he tried to connected to vpn client port 80,it's not showing blank screen.also i sent a network daigram.
Thanks.
diagram appears to be removed. Can you upload it one more time so i can download this time. Btw was the VPN client connected while you ran route print command in VPN client? Can you doublecheck if you can telnet the mail server on 192.168.100.1 on 80 while VPN connected?
IMPORTANT: According to the interfaces listed in route print ouput in VPN client, Cisco VPN client is not instaled. Are you using Microsoft client ?
Hi.............
   Please find the attachment for the network daigram .Also,"route print" file for the  cicso vpn client.Yes,I doublechecked.
   No i can't telnet the mail server on 192.168.100.1 on 80.Please need your helpful.
Thanks.
According to the actual configuration, all traffic (including internet) of VPN clients that belong to nexttoidea group is tried to be routed to corporate network. But tunnel group nexttoidea is not configured to tunnel-all. PC thath is connected via VPN client selects its local gateway as elected gateway, and traffic is not routed over tunnel.
In order to prove this theory, right-click VPN symbol in notification area, click statistics. While this window is open, open up a browser and type http://192.168.100.2 , and most probably the count of encrypted packets does not increment.
Assuming that your secuirty policy does not imply to restrict internet access or control all trafic centrally of nexttoidea members, I recommend using split tunneling. If you agree with my assumption and you need this VPN just to be able to connect your networks, while being able to connect local networks, do the following configuration
ip local pool next_to_idea 172.16.2.1-172.16.2.10 mask 255.255.255.240
tunnel-group nexttoideavpn general-attributes
no address-pool nexttoidea
address-pool next_to_idea
no ip local pool nexttoidea 182.16.1.1-182.16.1.10 mask 255.255.255.0
no access-list inside_nat0_outbound extended permit ip 192.168.100.0 255.255.255.192 182.16.1.0 255.255.255.240
no access-list inside_nat0_outbound extended permit ip 192.168.100.64 255.255.255.192 182.16.1.0 255.255.255.240
no access-list inside_nat0_outbound extended permit ip any 182.16.1.0 255.255.255.240
access-list inside_nat0_outbound extended permit ip 192.168.100.0 255.255.255.128 172.16.2.0 255.255.255.240
access-list outside_cryptomap_20 extended permit ip 192.168.100.0 255.255.255.0 172.16.2.0 255.255.255.240
access-list splitTun_nextoidea standard permit 192.168.100.0 255.255.255.128
group-policy nexttoideavpn attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value splitTun_nextoidea
Hi......
   yes....i put this commands for following configuration in cisco ASA.After VPN client is connected.But,
   I can't able to ping 192.168.100.1 my server ip.
   Kindly do the needful.
Thanks.
Please post the new config, and post the output of "route print" again after config update from VPN client when it is connected.
Need the output of following
*Log into ASDM. Apperantly logging to ASDM is enabled. Go to Real-Time log viewer. Set logging to Debugging level. Into filter-by section, type in the IP address that VPN client acquired (172.16.2.x)
Now in VPN client, try to browse http://192.168.100.1 again. After that,
1)Check the real-time viewer. Paste here the logs that occured .
2)In VPN client, right-click the VPN icon at notification area, click statistics, take a screenshot and paste here
Hi......
    Please find the attachment for the new config,Also post the output of "route print".And no output showing for ASDM log.
Thanks.
Hi.......
I have configured remote access VPN with local pool in ASA firewall.However i am accessing all the resoureces(My private network such as server's).
Also I can access the VPN through webmail.The port like,
port-object eq 443.
Thanks for your co-operate.
Thanks.
Hi.......
I have configured remote access VPN with local pool in ASA firewall.However i am accessing all the resources(My private network such as server's).
Also I can access the VPN through webamil.Port like,
port-object eq 443
Thanks.
Hi...........
I have configured the remote access VPN with local pool in ASA firewall however i am accessing all the resources.Also i can access the VPN through webmail.Port like,
  port-object eq 443
Thanks for your co-operation.
Thanks.
Hi.........
I have configured remote access VPN with local pool in ASA firewall.However i am accessing all the resources.(My privte network such as servers).
Also i can access VPN through webmail.The port like,
port-object eq 443
Thanks.
"whenever he tried to connected to vpn client port 80"
     I didnt understand. I mean, VPN client should try to telnet 192.168.100.1 on port 80, not to be telnetted. Instead of pinging the server, use telnet on port 80.
     Diagram is usefull. Please post the outut of "show ip route" command from 3560G core switch?
     Please post the output of "route print" command from exchange server's command line (cmd).
     Please post the output of "show ip route" command from firewall.
     Please post the output of "route print" command from the VPN client cmd line
     Did you set syslog? Did you get any syslog entries when you tried to connect exchange server on port 80 via telnet from VPN client?
Hi......
   Please find the attachment for the "route print" &  "show ip route" files.
Thanks.
866
