ASA flash issue
Hi all,
I'm trying to upload an 11 meg file (AnyConnect) to my internal ASA flash, and I'm seeing the following error:
%Error copying disk0:/anyconnect-macosx-i386-3.1.05152-k9.pkg (No space left on device)
When I dir flash:, I see this:
255426560 bytes total (185180160 bytes free)
... Thoughts? I thought maybe it was something like the old 'squeeze' function needed to happen, but that doesn't exist.
Thanks in advance,
Ryan
  • Firewalling
Hall of Fame Super Silver
ASA flash issue
Ryan
That does seem strange. What do you get from dir disk0:
Rick
ASA flash issue
Hey Rick,
Looks pretty normal to me. Not sure if this is a good candidate for a manual fsck or reboot.
It's 8.2(5) as you can see from the file in flash, for what it's worth.
ASA#dir disk0:
Directory of disk0:/
82     -rwx  15390720    20:10:04 Sep 07 2012  asa825-k8.bin
10     drwx  8192        00:22:10 May 21 2008  crypto_archive
83     -rwx  18927088    20:10:42 Sep 07 2012  asdm-649.bin
3      drwx  8192        08:52:02 Jul 03 2008  log
11     drwx  8192        20:14:08 Sep 07 2012  coredumpinfo
90     -rwx  24996       14:53:03 Feb 06 2014  backup-2-6-2014
95     -rwx  35167466    17:21:02 Feb 06 2014  anyconnect-win-3.1.05152-k9.pkg
VIP Green
ASA flash issue
You could try running the command fsck flash:
This command will check the flash for any corrupt sectors and attempt to repair them.  The command is normally run automatically when you restart the ASA also.  try running it and see if you are able to upload your file after.
Please remember to rate and select a correct answer
-- Please remember to rate and select a correct answer
Hello Marius,
Hello Marius,
did you resolve this? i have the same problem, it says there's 98 mb free, i try to copy a 16 mb file and it says no space left..
When I had an issue with
When I had an issue with writing to disk on an ASA TAC gave me these suggestions:
1) try fsck disk0  which will look for errors and attempt to repair them.
2) if that does not fix the issue then try reboot. This will dismount and then remount the disk and may fix issues.
3) if that does not fix the issue try to format the disk.
The symptoms that I was dealing with were slightly different that what is described here but I believe that the advice applies here. In my case Cisco determined that it was a hardware issue on the ASA and did an RMA. So if your ASA is covered by an active maintenance plan it would be worth it to open a case with Cisco (I would do it if the reboot does not resolve the issue and see what they say before I tried to format the disk).
Rick
Thank you Richard.
Thank you Richard.
after the restart, it worked, i'm  glad i didn't have to format the flash :)
I am glad that you got it to
I am glad that you got it to work without needing to format the flash. Thank you for posting back to the forum to tell us that you have it fixed and how you did it. This will be helpful for other readers of the forum. +5 for you.
Rick
Flash access errors on ASA´s
Flash access errors on ASA´s are fairly common. I saw a couple each year.
For me, fsck disck0 usually works.
Never needed an RMA nor format.
(I always hold breath breath while fsck is working, for step 2, just pray)
Guido.
I had the same issue with an
I had the same issue with an ASA that had 222MB of free space (I was copying up a new AnyConnect client package that was 38MB). fsck didn't work for me, but the reboot did.
Thanks Richard!
366
