ASA GNS3 project working
Does anyone have a ASA GNS3 working project?
I configured one, but i´m not having very sucess in making things work. I´m following Cisco matterials, but very strangly, simple things dont work.
So I need to know what the problem is, my instalation of asa, my installation of gns3 or my skills.
Kind Regards,
António
2 ACCEPTED SOLUTIONS
Super Bronze
Re: ASA GNS3 project working
Ok,
Lets try "packet-tracer" command to simulate a ICMP Echo arriving from R1 to ISP-R1
Insert the following command on the ASA CLI and copy/paste the output here
packet-tracer input inside icmp 192.168.200.1 8 0 62.28.190.65
- Jouni
Super Bronze
You have targeted the actual IP address of the server in the DMZ in the "packet-tracer" command. You will have to use the NAT IP address as the target as we will naturally be simulating traffic that would be coming towards the public IP address rather than a private IP address
So try for example
packet-tracer input outside icmp 10.0.0.1 8 0 62.28.190.66
packet-tracer input outside tcp 10.0.0.1 12345 62.28.190.66 80
- Jouni
Super Bronze
I don't really know much about GNS3 as I have not really used it.
However I am not sure if your problem is something related to installing the actual software and the devices in that software OR is the problem more with the actual device configuration?
I can't really help with the GNS3 software related problems but could have a look at actual ASA configurations if those are the actual problem.
- Jouni
My first post whas this one.
https://supportforums.cisco.com/thread/2237390
-AS
Super Bronze
So is there some problem with traffic passing through the ASA?
If there is some problem with traffic passing through the ASA then provide the current configuration of the ASA and description on what is not working.
- Jouni
The configuration is on this post:
And a simple ping from the inside to outside interface doesn´t work.
I configured :
  1. The interfaces
  2. The NAT. Dynamic nat in the outside interface
  3. And the policy map to inspect icmp and the default traffic
So, after this configs the ping form inside  [SecLevel 100] to Outside [SecLevel 0] sould pass?
-AS
Super Bronze
The ICMP working depends on the what the destination IP addres is. I dont what you are using in the tests
It also has a strange configuration related to the network 10.0.0.0/24
The mentioned network is both directly configured on an ASA "management" interface and there is also a static route for the network pointing towards the "outside" interface. If the "management" interface is up then it means that traffic destined for network 10.0.0.0/24 is forwarded through the "management" interface and the static route configured for the network is useless as connected router always overrides a static route.
- Jouni
To test ping, I try to ping from R1(192.168.200.1) to IPS_R1(62.28.190.65).
About that route. I allready removed it and doesnt work the ping traffic.
Tell me:
Interfaces are ok?
NAT is ok?
Policy map is ok?
It must be something else man...
Super Bronze
How are you using the source address 192.168.200.1?
If you simply type "ping x.x.x.x" then the ASA will use the "outside" interface IP address as the source. If you specify the "inside" interface as the source  in the extended ping then the traffic will go through WIHTOUT NAT.
NAT will not be applied from the ASA itself to my understanding.
So  you should use some host/device behind the "inside" interface to test ICMP / PING.
- Jouni
When I ping from the ASA I ping every device. No problems with that.
But when I try to ping from the router. that is in the inside interface lan I just can make it pass through.
So no problem with routing.
More: From R1 I even cant ping asa public IP 62.28.190.66.
Super Bronze
You can only ping the interface IP address of ASA behind which the host is.
So hosts/networks behind "inside" can ping "inside" interface. Hosts/networks behind "outside" can ping the "outside" interface IP address. Hosts behind "inside" CANT ping the "outside" interface IP address.
- Jouni
So I can´t ping google(ouside) from the inside network of my company. Is that what you are saying?
I´m sorry this just have to be a miss understude.
Imagine ISP_R1 is Vodafone router, my ISP. And ASA is between that router and R1(my company 2911). You are saying that I cant ping google through my ISP? Huumm.
Super Bronze
You mentioned that you were trying to ping the ASA "outside" interface IP address from R1 192.168.200.1 which is behind "inside" interface. This is not possible and is expected behaviour.
The only place where you can ping "outside" interface is from networks/hosts that are behind "outside" interface according to the ASAs routing table.
So you should be able to ping the ISP-R1 from the R1 but not the ASA "outside" interface.
If this was an actual ASA in live environment then you would naturally need a default route pointing towards the ISP-R1 on the ASA. Otherwise the ASA wouldnt know where to forward traffic destined to remote network.
- Jouni
But in the case of the ISP_R1, the ASA is directly conected to that route. It needs a route any way?
-AS
Super Bronze
No, I mean in a live network it would require a default route to actually route traffic to remote network that are not directly connected to it.
I am not sure what the problem at the moment is. So far if I understood correctly, the problem was that you couldnt ping the ASA "outside" interface from the R1. And as stated this is something that can be expected as the ASA doesnt allow that in any situation.
- Jouni
I meant to say:
From R1 I want to ping ISP_R1. This let me know if the traffic icmp reaches the ISP and the inspect is working.
But its not working with that config.
-AS
Super Bronze
Ok,
- Jouni
Super Bronze
Also just to confirm,
Seems to me that the R1 is mentioned to having IP 192.168.200.1 though it also seems that the ASA is configured with the same IP address of 192.168.200.1?
Are these the actual configurations as this naturally wouldnt work.
What are the interface IP address of R1 and ASA "inside" interface at the moment?
Does the R1 have a default route poiting towards the ASA "inside" interface IP address so R1 knows where to send traffic destined to other networks?
- Jouni
If you see in the config R1 is 192.168.200.1 and ASA is .254.
Yes the R1 have the route to the 62.28.190.64 network through interface f0/0.
Does have to be through the next hope?
In a minute ill have the output. Initiating the VM
Hi.
Here are the screen shots:
HI,
The firewall lets pass it. So its very strange man. The routing in r1 and ISP_R1 and fine. Correct?
-AS
Super Bronze
Both Router routing tables list the 62.28.190.64/30 network as directly connected? Also the network 192.168.200.0/24 is mentioned on both routers? Those dont really make sense.
The R1 should have a Static Route
ip route 62.28.190.64 255.255.255.252 192.168.200.254
Or typically it would probably have a default route if the router doesnt have any other way out of the network.
ip route 0.0.0.0 0.0.0.0 192.168.200.254
Also the other discussion you linked says that the ASA "inside" is configured with IP address 192.168.200.1
interface GigabitEthernet4
nameif inside
security-level 100
ip address 192.168.200.1 255.255.255.0
- Jouni
Super Bronze
And as you can see, the ASA "packet-tracer" simulation goes through without problems.
The actual problems seems to be related to the routers in the setup.
- Jouni
Jouni,
I´ll correct the routing problems and ill tell you more about it later.
Many thanks. You saved me a lot of time.
[]´s
António
Hi Jouni,
I were totaly rigth. Routing problems.
Jouni Rocks
Take care man.
- AS
Super Bronze
Glad to hear you got it working
- Jouni
Hi Jouni,
At this moment I´m experiencing a problem with NAT. Can you checks this plz?
Network Diagram:
ASA configs:
: Saved
: Written by enable_15 at 19:26:55.559 UTC Wed Sep 4 2013
ASA Version 8.4(2)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0
nameif outside
security-level 0
ip address 62.28.190.66 255.255.255.252
interface GigabitEthernet1
shutdown
no nameif
security-level 0
no ip address
interface GigabitEthernet2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet3
nameif dmz
security-level 70
ip address 192.168.100.254 255.255.255.0
nameif inside
security-level 100
ip address 192.168.200.254 255.255.255.0
interface GigabitEthernet5
shutdown
no nameif
no security-level
no ip address
no ftp mode passive
object network Net-Inside
subnet 192.168.200.0 255.255.255.0
object network Net-Dmz
subnet 192.168.100.0 255.255.255.0
object network webserver-dmz
host 192.168.100.1
access-list OUTSIDE_DMZ_WEB extended permit tcp any host 192.168.100.1 eq www
access-list OUTSIDE_DMZ_WEB extended permit tcp any host 192.168.100.1 eq https
access-list OUTSIDE_DMZ_WEB extended permit tcp any host 192.168.100.1 eq whois
access-list OUTSIDE_DMZ_WEB extended permit icmp any host 192.168.100.1
pager lines 24
mtu outside 1500
mtu dmz 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-702.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
nat (dmz,outside) dynamic interface
nat (dmz,outside) static interface service tcp www www
access-group OUTSIDE_DMZ_WEB in interface outside
route outside 10.0.0.0 255.255.255.0 62.28.190.65 1
route inside 192.168.15.0 255.255.255.0 192.168.200.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
console timeout 0
no threat-detection basic-threat
no threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
crashinfo save disable
Cryptochecksum:cb29abf617f52ce87c186e7aacc36cb5
: end
Packet tracer for ICMP from outside to DMZ
Packet tracer for HTTP from outside to DMZ will be post in message the insert picture crasshed.
Super Bronze
So try for example
- Jouni
Pass both.
Forget man, I was testing in wrong way.
I tried to access and ping 192.168.100.1(Private Adress). Access Private addresses from outside ins´t possible with this config.
Thanks again.
1316
