Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA Hub-and-spoke VPN dhcp-relay
Hi!
Have anyone implemented a solution with a hub-and-spoke IPSEC VPN (running ASA) with dhcp relay for the inside clients on the spoke. With the DHCP server on the hub site?
Normal LAN-LAN IPSEC VPN is a bit cumbersome to configure something like below:
SPOKE
<snip>
access-list CRYPTO_ALLOWED extended permit ip INSIDE-NETWORKS any
#ALL INTERNET ACCESS GOES THROUGH THE SPOKE SITE
access-list CRYPTO_ALLOWED extended permit udp host OUTSIDE_IF_ADDR host HUB_DHCP_SERVER_ADDR eq bootps
access-list CRYPTO_ALLOWED extended permit udp host OUTSIDE_IF_ADDR host HUB_DHCP_SERVER_ADDR eq bootpc
nat (INSIDE,OUTSIDE) source static CRYPTO_ALLOWED CRYPTO_ALLOWED destination static OSKO-INTERNET OSKO-INTERNET route-lookup
dhcprelay DHCP-SERVER outside
dhcprelay enable INSIDE
dhcprelay setroute INSIDE
dhcprelay timeout 60
HUB
<snip>
access-list CRYPTO_ALLOWED_TO_SPOKE extended permit ip 0.0.0.0 0.0.0.0 HUB_NETWORKS
access-list CRYPTO_ALLOWED_TO_SPOKE extended permit udp host HUB_DHCP_SERVER_ADDR host SPOKE_OUTSIDE_ADDR eq 67
access-list CRYPTO_ALLOWED_TO_SPOKE extended permit udp host HUB_DHCP_SERVER_ADDR host SPOKE_OUTSIDE_ADDR eq 68
nat (INSIDE,OUTSIDE) source static ANY ANY destination static SPOKE_NETWORKS SPOKE_NETWORKS
nat (INSIDE,OUTSIDE) source static HUB_DHCP_SERVER_ADDR HUB_DHCP_SERVER_ADDR destination static SPOKE_OUTSIDE_ADDR SPOKE_OUTSIDE_ADDR
### HUB INTERNET ACCESS ##
nat (OUTSIDE,OUTSIDE) source dynamic SPOKE_NETWORKS interface
I can't really apply this to a hub-and-spoke configuration.
Any ideas?
Daniel
Everyone's tags (1)
78
