Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Asa implicit rule inside network
we added a new network to the inside behind an ASA. The asa is acting as the gateway for some reason we can't route to the other network it's hitting the inside firewalls access list the implicit rule.
any ideas
1 REPLY
If the trafic needs to be send out through the same interface, you will need special configuration called U turning "Hairping"
Refer to the following:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807968d1.shtml#solution2
Mike
Mike
334
