Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA in HA -problem
Hi.. i have two ASA 5525 running as Active & failover. I am facing some problen here. When i reboot active ASA then standby become active but when active ASA comes up, it doesnt become active. Standby ASA remains active.
is this default behaviour or there is some config issue.Pls help.
1 ACCEPTED SOLUTION
Hi Anukalp, Yeap. Thats the
Hi Anukalp,
Yeap. Thats the default behaviour. If you want to make the primary unit back in to active state.... you have to issue failover reset on active unit to make the actual primary unit to active.
You can go through the below mentioned document which will be helpful for you in configuring failover .
http://www.cisco.com/c/en/us/support/docs/security/pix-500-series-security-appliances/77809-pixfailover.html#Shweow
Karthik
Hi Anukalp,
Karthik
Community Member
  Thanks nkarthikeyan...
76
