ASA initial settings
I'm working on my new ASA 5505 7.2(3)
I have few basic questions:
1. should I upgrade the software to 8.x? (I see it on the attached CD) if the answer is yes, what would be the best practice for that process?
2. generally I want all trafic to go out as A.B.C.x/24
for email (as an example but not just email) I want to use a different IP on the same ISP set of /24. how do I configure it to go out as A.B.C.y/24?
  • Firewalling
Re: ASA initial settings
1. Upgrade to 8.x = I would suggest you check the release notes at
http://www.cisco.com/en/US/docs/security/asa/asa80/release/notes/arn803n.html
2. If your internal network (inside) is A.B.C.x/24 and you want to send these ip's to Outside as A.B.C.y/24 , use this command
static(inside,outside) A.B.C.y A.B.C.x netmask 255.255.255.0
Hope this helps.
1. yes upgrade. There is only one way to upgrade, I guess it could be considered 'best practice' :-)
http://cisco.com/en/US/partner/products/ps6120/products_configuration_example09186a008067e9f9.shtml
2. You use the static nat commands in general to accommodate what you are asking for.
http://cisco.com/en/US/partner/products/hw/vpndevc/ps2030/products_tech_note09186a00804708b4.shtml
Both those links will get you started.
both links won't open, does it require special entitlements?
97
