Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ASA issue - policy map
Please do somebody know - if I adjust in policy map on ASA two classes - first for specific ip addressess (for which I dont want H323 inspection) and second global-all addresses all inspections. It means that packets from first rule will also conform to second rule. What is the processing order of these classes in policy-map about? It takes it gradually like access-list?
1 REPLY
Re: ASA issue - policy map
Only the first class-map is evaluated for 'each' feature type in a Layer3/4 Policy-Map. You can verify this via a 'show service-policy ... ' command.
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/mpc.html#wp1116212
Farrukh
234
