Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA issue routing packets to wrong interface
Looking for help/advice with the following problem: We have an ASA5520 running ver 7.0(8), nat-control is disabled. On the "outside" interface we have a closed network which is publicly addressed i.e. no access to Internet. We also have two Vlan interfaces on a trunk connection i.e. "inside" interface (Vlan7) and "dmz" interface (Vlan802). Traffic from the "outside" to "inside" is statically NAT'd such that the public IP is translated to a private IP when accessing the "inside" interface. However, our OSS servers on the "dmz" interface need to be able to receive packets from the public IP addresses on the "outside" . All is okay with the outside to inside traffic and traffic initiated from the OSS servers on the "dmz" to the outside works okay (snmp gets etc) i.e. the servers receive reply packets from the public addresses of the outside devices.
However, traffic that originates on the "outside" interface (snmp traps etc) which is destined for the "dmz" is actually being routed to the "inside" interface and therefore the public source address is being NAT'd by the static NAT command. The access-list "in_on_outside" has relevant entries to allow connectivity from outside to dmz, we have tried a static nat command (outside, dmz) to maintain the public addressing but this made no difference and also a nat exempt.
With nat-control disabled - do I still need a translation or NAT exempt for the "outside" <> "dmz" traffic flow, if so how should this look ?
Everyone's tags (1)
Super Bronze
Can you post configurations of the interfaces and NAT and perhaps the ACLs too.
- Jouni
Community Member
Config of interfaces and NAT :-
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.248 standby x.x.x.y
interface GigabitEthernet0/1
description STATE Failover Interface
interface GigabitEthernet0/2
no nameif
no security-level
no ip address
interface GigabitEthernet0/2.7
vlan 7
nameif inside
security-level 100
ip address 10.178.8.64 255.255.255.0 standby 10.178.8.65
interface GigabitEthernet0/2.802
vlan 802
nameif dmz
security-level 90
ip address 10.10.120.1 255.255.255.0 standby 10.10.120.2
nat (outside) 0 access-list exempt
static (inside,outside) 10.0.0.0 10.0.0.0 netmask 255.0.0.0
static (dmz,outside) 10.10.120.0 10.182.120.0 netmask 255.255.255.0
static (outside,inside) 10.10.191.0 z.z.z.0 netmask 255.255.255.0       ***real publics removed****
The following host to host ACL was created as a test in an attempt at NAT exempt:-
access-list exempt extended permit ip host z.z.z.244 host 10.10.120.10
Super Bronze
Your firewalls software should already include the "packet-tracer" command.
Can you use the "packet-tracer" command on the command line interface for the traffic that is problematic and post the whole output here
The command format is:
packet-tracer input
The input interface is the interface from where the connections is initially established from.
- Jouni
Super Bronze
Also atleast the following command seems abit strange:
Is there really a network 10.182.120.0/24 behind the DMZ interface?
- Jouni
Community Member
Jouni.
Packet tracer does not seem to be available in this version of software:-
# packet-tracer ?
ERROR: % Unrecognized command
Also, apologies for the typing error, the above static should read :-
static (dmz, ouside) 10.10.120.0 10.10.120.0 netmask 255.255.255.0
I don't think this is actually necessary as nat-control is disabled but at the same time I don't think it will be causing the problem (sorry inherited most of this config).
Super Bronze
Seems I remembered wrong. The packet-tracer command was introduced in 7.2(1) software.
Could you maybe try the connection and at the same time gather log through ASDMs monitor window and post a screencapture here.
- Jouni
Hi Paul ,
As you have disabled nat-control, I would try to delete :
The configuration - without those nat/static statements look straigh forward. With nat-control , there is no need for nat in any direction.
How do you know that your traffic is forwarded to the inside interface ?
Dan
Community Member
Yes - I will try to arrange to have those statements removed, I agree they should not be needed. Having said that I don't think they will be contributing to this problem?
I have captured traffic on all interfaces and can see the packets arrive on the "outside" interface and leave on the "inside" interface - no sign of them on the dmz interface.
Jouni - sorry we don not use ASDM only cli.
Re: ASA issue routing packets to wrong interface
Paul , the only doubt that I have is with :
even though the 10.10.120.0/24 is direcly connected but still part of 10.0.0.0/16 used as identity nat
Dan
Community Member
Dan,
Looks like your suspicions were correct - removing that static seems to have resolved the problem - thanks very much for your help :-)
Glad to hear that Paul.
Dan
1892
