Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA ISSUE -URGENT
I have two hosts in the DMZ VLAN and when they try to ping its gets first reply and then timeouts, after troubleshooting I found out that these two host ARP to ASA mac-adress and this is strange beacuse they are in the same VLAN.
What will be the effect on my ASA i disable proxy arp on DMZ interface.
I have DMZ host talk to Inside and vice versa, and also outside and vice-versa. All this works fine, except the host on the same VLAN on DMZ.
Any suggestions what might be wrong.
SK
1 REPLY
Re: ASA ISSUE -URGENT
I dont quite understand the second part of your statment but as for getting only one reply from a ping this could be normal behavior if you have ICMP inspection turned on
194
