Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA issue
Hi all
I have firewall with three zones namely inside,outside and DMZ.On the DMZ we have webserver and static NAT is given on the firewall.From outside i can access the webserver using public IP.But from Inside i cannot access on Public IPs or any of Public IPs on our network.Is there any way to access our public IP from inside?
Re: ASA issue
You need configure a static nat on the inside interface for the DMZ server IP.
HTH>
Community Member
Re: ASA issue
Thanks Andrew for the quick response can u please give one example
Re: ASA issue
I would try something like:-
static (DMZ,inside) <> <> netmask 255.255.255.255
HTH>
Community Member
Re: ASA issue
Thanks Andrew.but which internal Ip i should give because the server is in DMZ
Re: ASA issue
OK - let me explain:-
(DMZ = Source Interface, inside = Destination interface) <> <>
130
