ASA Issues
hello all,
we have this current network setup:
our ASA firewall only passes one subnet.. supposedly 2 subnet must pass to the ASA firewall.. any suggestions?
thannks a lot.
Super Bronze
ASA Issues
Can you clarify the situation a bit.
Do you mean that one internal subnet is able to connect through the ASA to the Internet or what do you mean?
Naturally if this is the case then the most common places to look are NAT, Routing and ACLs
- Jouni
ASA Issues
hi Mr.JouniForss..
as you can see in my ASA Firewall..it has two connection, it has One subnet each going to the servers.. now the ASA Firewall wont allow 2 subnet to enter.. only 1 subnet will pass.. which makes the other server passive.. my goal here is to make the server all active,
thanks
Super Bronze
ASA Issues
As I said you are most likely missing some NAT or ACL related configuration.
Also your above statement doesnt really clarify what you have attempted to do to troubleshoot this so far.
Without seeing any configurations I can only suggest what things to look for in the ASA configurations.
- Jouni
145
