ASA LAN Based Failover
I am using ASA 5540 and trying to implement LAN Based Active/Standby Failover using Management Interface. It seems that failover is possible but not the Stateful failover. Can anybody confirm me... about it that using Mngt interface I can not do Stateful Failover??
Thanks in Advance.
Adnan
Re: ASA LAN Based Failover
You should be able to configure stateful failover with the ASA5540s. This is not supported only in the ASA5505s.
Pls. follow this link for sample config.
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/failover.html#wp1064158
Hi Adnan,
To use the management interface for non-management traffic, you need to
remove the command 'management-only' from the interface configuration.
At that point you should be able to use that interface like any other
hth
Stefan
132
