Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA Lan & statful failover on subinterfaces
Has anyone of you guys configured Lan & stateful failover interface on a single physical interface with two subinterfaces dedicated for each?
I am configuring 5520's in an Active/Standby mode and falling short on the physical interfaces...
Pls advise or refer any cisco documentation regarding the same.
Gold
Re: ASA Lan & statful failover on subinterfaces
what do you mean "falling short on the physical interfaces"?
Just make sure you've used standby IP's on any interface with a regular IP.
You dont need to make any sub-interfaces. Just use the same 'physical' interface for both failover and stateful links. It works as long as your state traffic does not overwhelm the bandwidth of the interface.
Farrukh
146
