ASA linkstate issue
Hi, I'm setting up my first ASA. I'm able to serial into the device and have setup inside and management interfaces however none of the interfaces are able to establish link state with other devices on the LAN.
The interfaces doesn't appear to be sending out or responding to arp requests. idea's?
Can you post the config?
Thanks for the reply. I
Thanks for the reply. I looked in the config and saw that e0/0 was in a shut down state. Trying to remove it wouldn't work so I ran setup again. It removed the shut down state and resolved the linkstate issue.
Moving forward....thank you for your assistance
That is what I was going to
That is what I was going to check.
Mike
18
