ASA load-balancing over EIGRP not working
We have an ASA 5540 running 8.4(1) on the inside of dual Internet-facing border routers. The routers run BGP facing out and EIGRP facing in, with the ASA also running EIGRP for the same AS. Both routers redistribute a default route into EIGRP. It was my understanding and expectation that the ASA would learn both of these, as they are equal cost, and load-balance the outbound traffic over the two links. This does not appear to be the case.
The routers both have:
router eigrp 100
network nn.nn.nn.nn 0.0.0.0
redistribute static
passive-interface default
no passive-interface GigabitEthernet0/1
ip route 0.0.0.0 0.0.0.0 Null0 220
The ASA has:
router eigrp 100
network nn.nn.nn.0 255.255.252.0
no passive-interface XXXX-Outside
All three Gig interfaces are connected to the same VLAN on the same switch. Neighbor relationships are up.
Router: (only showing one, as they're the same)
Border1#sh ip eigrp nei
EIGRP-IPv4 Neighbors for AS(100)
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
0   nn.nn.nn.100          Gi0/1             13 1d03h     338  2028  0  32
1   nn.nn.nn.11           Gi0/1             12 31w0d       1   200  0  429
ASA:
ASA1# sh eigrp nei
EIGRP-IPv4 neighbors for process 100
                                            (sec)         (ms)       Cnt Num
1   nn.nn.nn.11           Gi0/0.920        14     1d03h 2    200   0   429
0   nn.nn.nn.10           Gi0/0.920        13     1d03h 1    200   0   551
However, on the ASA, we have
ASA1# sh eigrp top
EIGRP-IPv4 Topology Table for AS(100)/ID(nn.nn.mm.1)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
       r - reply Status, s - sia Status
P 0.0.0.0 0.0.0.0, 1 successors, FD is 2816
        via nn.nn.nn.11 (2816/256), GigabitEthernet0/0.920
ASA1# sh rout
Gateway of last resort is nn.nn.nn.11 to network 0.0.0.0
[snip]
D*EX 0.0.0.0 0.0.0.0 [170/2816] via nn.nn.nn.11, 27:30:50, XXXX-Outside
I expected to see both nn.nn.nn.10 and nn.nn.nn.11. Am I wrong?
  • Firewalling
Re: ASA load-balancing over EIGRP not working
it should as long as the 2 k values are equal.
What is the output of "show eigrp topology" on the ASA?
You could also consider the eigrp variance option, if supported.
Yes, I know it should work. I'm posting here because it doesn't.
The "sh eigrp top" from the ASA is in my original post.
ASA1# sh eigrp top
Purple
could you post sh eigrp topo all if it is present on ASA because I can't remember if it is supported on this platform.
Regards.
Alain
It's the same as "sh eigrp topo" I already posted except it includes the serno.
Purple
it should be displaying the paths that didn't meet the Feasibility condition so I thought maybe this second path was not a feasible successor so that's why it was not in th topology table.
I never saw serno in this output; sh eigrp topology all-links
Regards.
Alain
I'm not sure what you are saying. So, again, here is the output
ASA1# sh eigrp topo all-links
EIGRP-IPv4 Topology Table for AS(100)/ID(208.93.215.1)
P 0.0.0.0 0.0.0.0, 1 successors, FD is 2816, serno 85
Note that it is not getting a path from nn.nn.nn.10.
if you KNOW it does not work - explain why you do not think it works?
Because a) sh eigrp topo on the ASA has only the one path, which it learned from nn.nn.nn.11 and b) only the router at nn.nn.nn.11 is receiving traffic from the ASA. On nn.nn.nn.10, here's sh int Gi0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is MV64460 Internal MAC, address is 588d.0965.f01a (bia 588d.0965.f01a)
  Internet address is nn.nn.nn.10/22
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is RJ45
  output flow-control is XON, input flow-control is unsupported
  Last input 00:00:01, output 00:00:00, output hang never
  Input queue: 0/75/836/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 438000 bits/sec, 207 packets/sec
Clearly the second router has an issue with either not receving the routes, or does not populate them into the routing table, or there is a general neighbour issue.
I suggest you issue the "debug ip eigrp <>
then a "clear ip route *"
and watch the debug - this should be done out of production hours, and you should be on the console of the router just in case you lock it out.
1394
