ASA lossed features in Tranparent mode
Dear
i have two ASA firewalls working as Active-Active. the scenario requires that the firewalls have to operate in transparent mode.
i want know if i loss the below features in transparent mode:
- AIP-SSM module
- Contexts (Active-Active)
- DMZ zone
- Sub interfaces (VLANs)
regarding the final point; each firewall have to be connected to two different routers for internet connection's (i have four routers in total), as a result each context must have two outside interfaces (sub interfaces) and each sub interface has a different tag.
Re: ASA lossed features in Tranparent mode
Active-Active is supported.
DMZ Zone - The transparent security appliance uses an inside interface and an outside interface only( remember the restriction of 2 interfaces in transparent mode )
not quite sure about the other 2, But I did use sub-interfaces on a single PIX ( multi-context ) in transparent mode.
Vikram
Dear Sir
thank you a lot for your reply.
i want to derive benefit from your experience regarding splitting the outside and inside interfaces to sub interfaces.
i have two outside routers for internet connections have to e connected to the firewall, so i want to divide the inside and outside interfaces to two sub interfaces; because each outside router has differnet internal IP addresses .
but the question is that in transparent mode, each interface has to get different VLAN "does this mean that i have to give the interface a tag" so how can i access the routers from the inside; by this it will be different network ( the inside and the outside considered as different networks).
even though you configure different vlan-tag's on the inside & outside interfaces ( both the vlans share the same ip-address space ), that way having your gateway ip-address residing on the outside interface and hosts connected to the inside interface will help you in filtering the traffic as it passes through the firewall
check this example
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008089f467.shtml
even though the above example doesn't talk about context's it will help you understand the network design while implementing transparent firewall.
Vikram
119
