06-15-2010 04:28 AM - edited 03-11-2019 10:59 AM
I have conencted my management interface on core with a different vlan from which inside interface is connected,My inside interface is in vlan 100 and management interface is in vlan 150,i m not able to ping my SVI interface of management on core from ASA (directly connected). The line protocol is down on ASA but the cable are connected and light are also glowing on core and also in ASA.
Solved! Go to Solution.
06-18-2010 11:47 PM
Hello Federico / edadios
If you check the ARP table on the CORE do you see the MAC address of the management interface of the ASA?
no there is no MAC address of the ASA management interface
This CORE switch and the ASA are directly connected correct? With what type of cable?
yes directly connected by straight cable.
Dear Edadios,
Are you running the firewall in multicontext mode?
NO
Dear,
Federico and Edadios,anything else can be thing for the above problem
Message was edited by: thomasandy32
06-19-2010 12:15 AM
Hello Dears,
Just relaod the firewall and the interface was up.
Thanks averybody for ur support.
