Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA management
When running two ASAs as Active/Standby; is there a way to have two different management addresses using two different networks?
(In a failure each ASA should keep its mgmt address. Basically exclude the mgmt interface from config synchronization.)
Joe
Re: ASA management
yes you can have both devices on different management address and exclude from failover monitor...But you can only make active configuration chaange on the active device though!
Re: ASA management
It should be from the same network.
JK
~Jatin Katyal
Re: ASA management
yep. forgot to mentioned that. thanks JK.
Community Member
Re: ASA management
Would that require using the "standby" ip address on the mgmt interface with two different IPs but on the same subnet?
(I was hoping that the mgt interface config was not "synchronized.)
Joe
154
