ASA Memory upgrade (keep old modules)
mcroft
I am upgrading a ASA5520 to the lastest 8.4 image.
An onsite Engineer has installed the memory upgrade kit (2GB) for me.
However, he has left in the old 2x 256MB modules.
So now I have.
Slot1: 256MB
Slot2: 1GB
Slot3: 256MB
Slot4: 2GB
A Total of  2560 MB RAM
Is it a good idea to mix modules ?
I would say NO, as generally mixing clock speed and manufacture's is not good practise.
Should I have the original modules removed ?
Matt
S M85
Level 4
Level 4
Hi Mcroft,
A 5520 is not support with more ram as needed. So you need to pull out the old ram before you place the new RAM. Also the upgrade kit has always to modules: so 2 times 1 gig.
Also two units in a cluster with different amount of memory is not supported!
HW has to be the same.
http://www.cisco.com/en/US/docs/security/asa/hw/maintenance/guide/procs.html#wp1076043
Note
Some Cisco ASA 5510 have only a single memory socket, see
Figure 4-26
. while others have four memory sockets. In both cases, remove the existing DIMM, and replace it with the new one. For memory upgrade in the Cisco ASA 5510 with four memory sockets, use slot 1 - P13 and note that only one slot must be populated at all times.
