ASA Migration Problems
hellishglare
I'm trying to migrate a configuration of an ASA 5520(Version: ASA 8.0(5)) to an ASA 5585 (Version: 8.4(2)). I keep getting some errors which are included below. I've been struggling with these for some copule of weeks and read the documentation on cisco.com (
http://www.cisco.com/en/US/docs/security/asa/asa83/upgrading/migrating.html) and also some pages on this forum. Some lines are written in bold of which I wasn't able to find any information about. Any help is appreciated. Thanks.
INFO: MIGRATION - Saving the startup errors to file 'flash:upgrade_startup_errors_201203062349.log'
Reading from flash...
!!!!!!!!!!!!!!!!!!!WARNING:
MIGRATION: NAT Exempt command is encountered in config.
Static NATs which overlap with NAT Exempt source are not migrated.
Please check migrated ACLs for accuracy.
WARNING: MIGRATION: Failed to create acl element to track during migration
*** Output from config line 1291, "access-group outside_acc..."
WARNING:
*** Output from config line 1292, "access-group inside_acce..."
WARNING:
*** Output from config line 1293, "access-group DMZ_access_..."
WARNING: MIGRATION: During migration of access-list <XXXXXXX> expanded
this object-group ACE
    permit object-group DM_INLINE_SERVICE_5 XXX 255.255.255.0 DMZnet 255.255.255.0
*** Output from config line 1298, "access-group XXXXX..."
ERROR: MIGRATION: No memory to create migrated service-policy element
ERROR: Problem with interface 2
ERROR: Problem with interface 3
ERROR: Problem with interface 4
ERROR: Problem with interface 5
ERROR: Problem with interface 6
ERROR: Problem with interface 7
ERROR: Problem with interface 8
ERROR: Problem with interface 9
ERROR: Problem with interface 10
ERROR: Problem with interface 11
*** Output from config line 1797, "service-policy global-po..."
NAT migration logs:
The following 'nat' command didn't have a matching 'global' rule on interface 'dmz' and was not migrated.
nat (inside) 1 access-list inside_nat_outbound
WARNING: The following identity NAT was not migrated. If required, an appropriate bypass NAT rule needs to be added.
global (outside) 10 interface
nat (inside) 0 logserver 255.255.255.255
nat (inside) 1 icnetwork 255.255.0.0
The following 'nat' command didn't have a matching 'global' rule on interface 'TAV' and was not migrated.
nat (dmz) 1 access-list dmz_nat_outbound
INFO: NAT migration completed.
ERROR: an object-group with the same name (egitim) exist.
WARNING: Failed to create an object for name 'egitim' in the following ACL:
access-list DMZ_access_in extended permit tcp host 9.1.1.90 object-group egitim any
0 Replies 0
