Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA Multi-Context + sub-Interfaces
I am trying to configure two ASA 5525 in Active/Standby mode using multiple contexts and is in transparent mode. We are using trunk ports which are ether-channeled.
The problem we are having is the the ASA's alternate betwen active/standby with the following messages being seen
        Switching to Active
Dec 31 2013 10:23:48: %ASA-1-104001: (Secondary) Switching to ACTIVE - Other unit wants me Active. Primary unit switch reason: Interface check.
Dec 31 2013 10:23:58: %ASA-1-105003: (Secondary) Monitoring on interface management waiting
Dec 31 2013 10:24:08: %ASA-1-105004: (Secondary) Monitoring on interface management normal
        Switching to Standby
Dec 31 2013 10:24:16: %ASA-1-104002: (Secondary) Switching to STANDBY - Interface check
Dec 31 2013 10:24:38: %ASA-1-104004: (Secondary) Switching to OK.
Here is the configuration from the ASA's.
Active ASA
interface Ethernet0/0
speed 100
duplex full
channel-group 1 mode on
interface Ethernet0/1
speed 100
duplex full
interface Ethernet0/2
speed 100
duplex full
channel-group 2 mode on
interface Ethernet0/3
speed 100
duplex full
interface Management0/0
interface Port-channel1
speed 100
duplex full
interface Port-channel1.105
vlan 105
interface Port-channel1.106
vlan 106
interface Port-channel1.107
vlan 107
interface Port-channel1.108
vlan 108
interface Port-channel1.155
vlan 155
interface Port-channel1.156
vlan 156
interface Port-channel1.157
vlan 157
interface Port-channel1.158
vlan 158
interface Port-channel2
speed 100
duplex full
interface Port-channel2.801
description LAN Failover Interface
vlan 801
interface Port-channel2.802
description STATE Failover Interface
vlan 802
failover
failover lan unit primary
failover lan interface LAN-Failover Port-channel2.801
failover link State-Failover Port-channel2.802
failover interface ip LAN-Failover 10.xx.xx.12 255.255.255.248 standby 10.xx.xx.13
failover interface ip State-Failover 10.xx.xx.20 255.255.255.248 standby 10.xx.xx.21
admin-context admin
context admin
  allocate-interface Management0/0
  config-url disk0:/admin.cfg
context Context-1
  allocate-interface Port-channel1.105-Port-channel1.106
  allocate-interface Port-channel1.155-Port-channel1.156
  config-url disk0:/Context-1.cfg
context Context-2
  allocate-interface Port-channel1.107-Port-channel1.108
  allocate-interface Port-channel1.157-Port-channel1.158
  config-url disk0:/Context-2.cfg
Standby ASA
The same configuration except apart from the failover commands
failover
failover lan unit secondary
Can anyone see any issues with this configuration?
Many thanks
John
Everyone's tags (3)
Hi John-
You can't run Active/Passive failover with multiple contexts. You must run Active/Active. You can set one firewall to be Primary Active for all contexts if you want it to operate a little more like Active/Passive.
Hope it helps.
Silver
or use version 9.x
Posted by WebUser Erik Boss from Cisco Support Community App
Thanks for your reply.
I am running version 9.1(1) and it works fine until I failover to the standby firewall where it then flips between being active or standby every 30-60 seconds.
939
