Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA multiple context and sla monitor
Can I use both multiple context and sla monitor in my ASAs? I can not use sla monitor if enable multiple context. Please help to identify the problem.
Thanks & Best Regards,
Jackson Ku
Silver
Re: ASA multiple context and sla monitor
But it can not accept "sla monitor" command in my ASA with multiple security context?
Best Regards,
Jackson Ku
I also have the same issue.  We are running an ASA 5520 7.2(4) in multiple context mode.  I cannot enter the "sla monitor" command, as it is not recognised.
The only reference I can find regarding SLA monitor setup, is concerning the ASA 8.0 code.
SLA Monitoring on ASA
Problem:
SLA monitoring does not work after the ASA is upgrade to version 8.0.
Solution:
The problem is possibly be due to the IP Reverse-Path command configured in the OUTSIDE interface. Remove the command in ASA and try to check the SLA Monitoring.
Apologies if I am missing something blindingly obvious, however does anyone know why the command's don't seem to be recognised on our setup (multiple context, 7.2(4)?
Thank you for your help,
Kris
If you read this command reference link for sla monitor:
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/s8.html#wp1506676
It is only supported in single routed mode. See the table.
Command Modes
The following table shows the modes in which you can enter the command:
Command Mode
Firewall Mode
Security Context
Routed
Transparent
Single
Multiple
Context
System
Global configuration
-KS
Hi kusankar,
Thanks for your help - much appreciated!
Kris
2865
