ASA Multiple Context with SLA monitor
Hello
i have to setup two ASA 5520 Active/Active with multiple security context.
i need to configure tracking by sla monitor command.
is there any restriction exit , if so , is there any workaround
regards,
mibrahim
1 REPLY
Super Bronze
Don't believe there is any limitation of sla monitor on Active/Active failover configuration.
Dynamic routing protocols is not supported on Active/Active failover, however static routes with tracking is supported.
488
