ASA nat issue
My ASA running 8.4(4) is matching a nat entry when it is supposed to match a different nat statement. What might be wrong?
ASA nat issue
Hi Kashish,
can you post your nat configs?
show run nat and highlight which NAT should be executed in order.
Also include the subnets as you might of used group names that may not represent the actual network.
JR
ASA nat issue
Some backgroud info on NAT and how they are applied.
Twice nats are applied first, then object network nats with static and dynamic nats included.
What kind of nats are they?
ASA nat issue
I have sent you "show run nat" and "packet tracer" output. In "show run nat", I have mentioned which line it is matching and which one it is supposed to match.
ASA nat issue
ASA nat issue
Hello Kashish,
I was just about to send you that particular bug.
Great to hear that you fix it, please mark the question as answered so future users can learn from this,
Julio
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
969
