Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA NAT Issue
I have a Desktop with ip:10.10.3.4 in my network. In this PC internet working.
when i try to add the NAT command in Cisco ASA 5510 -  in this scenario 10.10.3.4 to some public ip X.X.X.X (one to one natting)
static (inside,outside) X.X.X.X 10.10.3.4 netmask 255.255.255.255
Issues are:
1. Internet on this local pc is not working (i.e.., 10.10.3.4)
2. Public ip also not accessable from outside.
Thanks for you valuable time and consideration.
Community Member
Just a shot in the dark -
Just a shot in the dark - have you added rules to permit the relevant traffic to your host?
Bronze
i believe you have already
i believe you have already the access-group outside inbound. Check the rules and in last case the Logs messages on Firewall because it help always
Community Member
I have already added the
I have already added the rules to permit the relevant traffic to my host.
how to check the logs messages on firewall?
Bronze
using ASDM:http://www.cisco
using ASDM:
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/113053-asa82-syslog-config-00.html#enablelog
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/113053-asa82-syslog-config-00.html#veri
Using CLI via console/telnet/
Configure the following on the Cisco ASA:
ciscoasa(config)#logging monitor 7
ciscoasa(config)#logging console 7
ciscoasa(config)#terminal monitor
ciscoasa(config)#logging on
ciscoasa(config)#logging trap 6
ciscoasa(config)#sh logg
58
