ASA NAT problems related to licensing?
We are trying to replace a pair of PIX515e's in HA mode on 6.35 with ASA5520's in Hot/Standby mode on 7.2.2. We copied the majority of commands successfully from the PIX's to the 515e's, but when did the swap out, all Dynamic NAT sessions failed to work. Non NAT sessions to the DMZ and external sites worked fine. In doing a show xlate, we see traffic properly PAT'd.
Are NAT sessions related to licensing? My colleague did not do any license installs, but a sh ver shows the primary box as active with vpn plus enabled.
1 REPLY
Re: ASA NAT problems related to licensing?
I don't think it has something to do with license, but probably the config/setup.
Try to run only one ASA at the time, and check your configuration as well.
What's the config looks like anyway?
AK
157
